- Kyle
- Oct 12, 2023
- 27
- 149
- 168
- Oxnard California
- 2022 Ford Bronco
- Badlands
Introducing the SSV Works 2023‑2024 Ford Bronco Factory‑Style 8″ Subwoofer Add‑On — a true factory-style, plug-and-play subwoofer upgrade for Broncos that didn’t come with a rear subwoofer from the factory.
Why this matters:
Fits right where the factory sub would go — OEM-style mounting with no trimming, drilling, or custom brackets required.
True plug-and-play: runs on your existing Bronco wiring with FORScan activation of the sub output harness, so it integrates cleanly with your stock system — even if your Bronco didn’t originally have a sub.
Delivers deep, rich bass that the stock setup just doesn’t have — perfect for road trips, campgrounds, or blasting your favorite tracks on the trail.
Built trail-ready — designed to handle dust, water, and off-road conditions just like your Bronco does.
How it works:
No cutting corners, no huge bulk boxes — just quality bass that looks and feels like it’s always been part of your Bronco.
If you’ve been thinking about adding real low-end to your audio setup without compromising that clean Bronco interior look, this is definitely worth checking out.
This is not a factory sub replacement. This is a factory-style add-on subwoofer
Head on over to SSV Works to learn more and DM me for a discount code offered to Bronco6G members only!
Why this matters:
How it works:
- Drop it right into the factory sub location.
- Connect to the factory sub wiring harness.
- Use FORScan to enable the rear subwoofer output.
- Enjoy beefy bass with a clean, OEM-level install.
