OracleLights
New Orleans, LA
www.oraclelights.com
We wanted to share one of the new products we debuted at SEMA this year for the steel-bumper Broncos: the ORACLE Lighting Laser + LED Fog Light Kit. It’s a modular setup that replaces the factory fogs with one SAE-compliant LED fog light for on-road use and two individual off-road Laser auxiliary modules for long-range visibility. The LED fog gives you a true cut-off and clean foreground lighting, while the Laser modules throw a hyper-focused beam over 3,000 feet for high-speed trail runs or open-desert driving.
Ford Bronco LASER + LED Triple Fog Light Kit for the 2021–2025 Bronco (Steel Bumper) by ORACLE Lighting Screenshot 2025-11-17 134237
Each projector sits in its own die-cast housing and can be individually aimed, so you’re not stuck with a single bracket that forces everything in one direction. The whole system mounts using factory hardware, keeps the front end clean, and the skeletonized steel bracket actually looks good — not bulky or tacked on. Wiring is simple: the fog light can run off the factory switch (if equipped) or AUX, and the Laser modules should be run off AUX. If you don’t have AUX switches, ORACLE makes a plug-and-play harness for that.
Ford Bronco LASER + LED Triple Fog Light Kit for the 2021–2025 Bronco (Steel Bumper) by ORACLE Lighting Screenshot 2025-11-17 134259
If you want the full details or beam specs, here’s the product page:
https://www.oraclelights.com/products/oracle-lighting-2021-2024-ford-bronco-off-road-laser-led-fog-light-kit-for-steel-bumper
Happy to answer questions or hear feedback!
mdainsd
2025 Bronco, 1974 Bronco, 1969 Bronco, 2014 Raptor, 2012 MegaRex
I am very happy with mine. The range is unlike anything else out there. Mine are on the mod bumper. Not quite sure what is being refered to as the steel bumper? Modular or capable?
Paul's silver pony
Paul
SC
24 wildtrak bronco
I enjoy my oracles. Going back in for a full replacement. Foggy up real wet not drying. Hopefully the new set will fix the issue. I know fogging is normal to an extent but they must dry. Great light when in use. Keeping my fingers crossed.
Ford Bronco LASER + LED Triple Fog Light Kit for the 2021–2025 Bronco (Steel Bumper) by ORACLE Lighting 20251117_072818
Ford Bronco LASER + LED Triple Fog Light Kit for the 2021–2025 Bronco (Steel Bumper) by ORACLE Lighting 20251117_072858
swamp2
Would love more detail on range and application for high speed night off roading. What is the illumination pattern? A video seems warranted with the range claims.
I did watch both the video on the Oracle site. Those didn't really help.
Thanks.
mdainsd
adcam
Mando
2025 Stroppe
Tempting with the 20% Off BF deal.
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
mdainsd
For lights with such a long throw like a laser light, wouldn’t it make more sense to use those up high like roof mounted driving lights?
Impressive. Have you used them off-road in a dusty environment? I am curious how they would perform.
My plan exactly. Six or eight of them up above line of sight and all should be awesome. Im a bit of a nut when it comes to off road lighting. These "fog" lights reach far further than Super Oscars, my go to for years. Havent powered them up next to my Light Force 240 Blitz lights.
OracleLights
OracleLights
New Orleans, LA
In this case we’re referring to the modular bumper — the one with the pocket that supports the triple-fog upgrade. Other bumper styles can be modified to fit the setup (OEM or aftermarket), but the modular bumper is the clean, direct-fit option.
OracleLights
OracleLights
New Orleans, LA
Thanks.
The setup uses two different types of optics depending on use case:
  • The main pod is a DOT SAE fog beam, designed for on-road use and general driving visibility.
  • The auxiliary units are the 15W laser modules, which are intended specifically for off-road, high-speed night driving. These are the same laser emitters we just released in the Vega 7 pods, so the range and punch are extremely similar.
We've attached additional photos showing the laser output so you can get a better sense of the pattern and distance. We’ve also been posting updated range videos and real-world testing clips on our Instagram if you want to see how they perform outside of studio/demo environments.
Ford Bronco LASER + LED Triple Fog Light Kit for the 2021–2025 Bronco (Steel Bumper) by ORACLE Lighting A7R01461
Ford Bronco LASER + LED Triple Fog Light Kit for the 2021–2025 Bronco (Steel Bumper) by ORACLE Lighting DJI_0091
Ford Bronco LASER + LED Triple Fog Light Kit for the 2021–2025 Bronco (Steel Bumper) by ORACLE Lighting DJI_0093
Phil
Phil
2022 Tesla Model 3 LR
Wow. The only thing stopping that light is the bend in the road. Very impressive.
mdainsd
I love mine. They installed easily and have worked flawlessly since. I'd like to put a set in my Gen1 Raptor one of these days...
OracleLights
OracleLights
New Orleans, LA
Love to hear that, we appreciate the feedback! More Ford products are big on our list for 2026, so stay tuned!
OracleLights
OracleLights
New Orleans, LA
@mdainsd Could you link to the review thread you made?
