Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
Ford Bronco Introducing the C2R—Compact Triple-Function Lighting | Diode Dynamics tTLcDwD
Meet the newest addition to our Stage Series lineup, the C2R LED Pod.
Built on the larger C2 2.0 platform, it combines the proven versatility of the C1R with a boost in performance and more mounting options. Whether it’s backing up, adding a chase light, or running as a 4th brake, the C2R delivers powerful, reliable lighting in a compact package.
Ford Bronco Introducing the C2R—Compact Triple-Function Lighting | Diode Dynamics HbawpJj
Ford Bronco Introducing the C2R—Compact Triple-Function Lighting | Diode Dynamics sujhFLO
With three fully integrated functions, the C2R is ready for anything. You get bright white output for reverse or work lighting, high-power red for brake or chase use, and a red accent running light for added visibility, all in one rugged, easy-to-install pod.
Ford Bronco Introducing the C2R—Compact Triple-Function Lighting | Diode Dynamics GPf9lwU
Ford Bronco Introducing the C2R—Compact Triple-Function Lighting | Diode Dynamics dCkYbgF
The C2R’s compact size and versatile mounting make it perfect for rear-facing applications. Install it on bumpers, roof racks, or bed racks to add powerful reverse, brake, or chase lighting right where it’s needed.
Ford Bronco Introducing the C2R—Compact Triple-Function Lighting | Diode Dynamics PS9IY9T
Questions/Concerns. Please go ahead and give us a call at 314-205-3033, Monday-Friday 10 a.m.- 5 p.m. CST, or shoot us an email at [email protected], and our in-house US service team would be happy to help you with that.
Hours: Monday-Friday 10 a.m. - 5 p.m. CDT
Email: [email protected]
Phone: 314-205-3033
Forum Exclusive. All forum members are eligible for a free US shipping code by sending us a direct message.
John C.
Social Media Community Manager
Diode Dynamics
Phil B
Phil
Plano Texas
2023 Bronco Wildtrak
When will you have a plug in wiring harness for the Bronco to go with this?
A kit that replaced the third brake light on the spare tire with two or three of these would be very cool.
Moontraveler1984
McCordsville, Indiana
2022 Wildtrak - for Bradford
100%
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
We don't offer a kit at this time, but you could build the kit easily if you have a Bronco equipped with a 7-pin trailer harness.
Ford Bronco Introducing the C2R—Compact Triple-Function Lighting | Diode Dynamics 1755521030207-iu
Reverse Light Bracket: https://www.diodedynamics.com/stage...nGt6cRIoirmXFTVMbQ96W62X0GzzDAmh-Q79uogJhyKyA
C2R LED Pods: https://www.diodedynamics.com/c2r-white-flood-standard-led-pod-pair.html
7-Pin Dual Output Harness: https://www.diodedynamics.com/stage-series-7-pin-dual-output-trailer-wiring-harness.html
If you have questions or concerns, you can call our in-house customer service team to add items to your cart required for assurance before checking out.
Phone: 314-205-3033
Hours: Monday-Friday 10 a.m. - 5 p.m. CST
Phil B
Phil
Plano Texas
I’ve seen it, and may go that route. I’m hoping by the time I’m ready to purchase, there will be a vehicle specific harness. (Please!)
rayofsi
Staten Island, NY
Raptor Gen2
i replaced my 3rd brake light with the 3x c1r when they first came out. works great!
This light makes me want to upgrade my rear bumper
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Our 7-Pin Harness is a universal solution that’s ready to use. Because of its versatility, there isn’t a need for a vehicle-specific version—it can already be configured for your setup. At this time, we just don’t have a dedicated listing created for your vehicle. To get the setup you want, simply add the components to your cart to build it out.
jalawson
TX
‘22 Bronco, ‘17 F150
Is there an SS3R coming?
jalawson
TX
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Bummer. Well if you did do it I would buy one.
Just the C1R and C2R at this time. Sorry about that!
We have put a request into our engineering team so you know your voice has been heard. Many members on the team have requested this push for a high-power red with the SS3, too. We'll see if we can make some movement happen!
Kach Vartan
Los Angeles
Sedan
Can we run these alongside your C1R hitch mounts using a single DD 7-pin harness? Ideally, I’d tie the spare tire mounted C2Rs and hitch mount C1R (which I already have) to the brake/reverse function and have the ability to turn the C2R on manually with an AUX switch. I would use the AUX feature and yellow lens caps for chase lights.
If too complicated I guess I can sell the C1R… Nice product by the way!
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
The 7-pin harness can’t support both the C1R and additional C2R pods together. The best route is to keep your C1R connected to the DD 7-pin harness as designed, and then run the C2Rs on a separate/custom harness. That way, you can still tie them into your brake/reverse signals if you’d like, while also wiring in an AUX switch for manual control and chase light use with the yellow lenses.
