12/19/2022 build week group
PDXOuterBanks
Hank
Portland
67 Nova
Has anyone with a 12/21/22 Blend date gotten any info about being bumped? i figured with the storm and Holiday we were put on hold??? Any intell would be appreciated. :oops:
well ford chat was useless. Thanks for wasting my time I guess?
I got the same BS.
Sasquatch_SOF
I’m guessing 12/20 blends were the last to get built before the plant goes on break. I’m not expecting my 12/21 blend to actually get built until after the new year.
12/20 blend here, pizza tracker shows in production 12/22 and mods and tear tag populated 12/23, so I think any blends 12/21 and later didn't make the cut before the holiday break.
Called Ford earlier today and was just told it's in production with a 1/14 delivery date.
Looking at the 12/12 build week Excel, this all makes sense, so fingers crossed!
Edit: I think mine may be in QC phase since I don't have a built date. I'm at least hoping that's the case and it's parked inside in the nice warm building away from the sub zero temps and high winds from last week.
Xjeepowner
Randy
Montgomery Texas
18 Camaro 16 JKU Rubicon
Mine finally showed today as built and awaiting shipping. Mine was a 12-20 blend date as well.
Ford chat said it should arrive at my dealership around the 18th.
I'm in North Houston.
Travo68
Travis
Houston, TX
Ford Edge/Fusion
North Houston here as well. Still waiting for the "Built" email, but ford chat said its been built and allegedly arriving at the dealer between 1/11 - 1/18.
What dealer are you using? I'm through Tomball Ford.
Sasquatch_SOF
Looks like you're 45/1127 for place in line which is the lowest # on the spreadsheet for that batch. I'm 367/1127, so let's see if I get the built status tomorrow or Thursday.
Sasquatch_SOF
Where do you see these place in line #s? 45/1127 etc
Top right of the window sticker in small print. Mine is right above the word "Environment."
Edit: I should also note that they are on the 12/19 Excel tracker for those that have populated that entry.
PDXOuterBanks
Hank
Portland
67 Nova
Mine says 3729/4135. That is why I asked because everybody else quotes numbers in the low thousands.
Ford Bronco 12/19/2022 build week group 85A33938-BACF-406B-9D00-58D10F2D4C6D
Sasquatch_SOF
So it looks like you're at the tail end of the 12/19 blend dates but ahead of the "1127" 12/20 blend date group I'm in.
Sasquatch_SOF
Another, and possibly better number to refer to is the rotation number which is to the right of your blend date on the window sticker. Based on your 3739/4135 and comparing it to the spread sheet, I gather your rotation number is 726. My understanding is vehicles come down the assembly line in sequence. My rotation number is 1489, so mine rolled down 763 vehicles after yours. The rotation number resets to 0001 after 9999 and is the primary number assembly workers are looking at. Ford also manufactures Rangers at the same facility, so I'm likely not 763 Broncos after you assuming a batch of Rangers are on the same line. If you refer to the 12/12 build sheet, you'll notice a number of people have the same "4135" group. For instance, Zombie Salamander is 110/4135 with a 12/15 blend date.
voxel
Nelson
Altamonte Springs, FL
Mach-E 4X, 23 GC Limited
Blend date 12/23 but still stuck in production with no modules.
