Valhalla
Valhalla
Chattanooga Tn
We started on trail thirty, it is rated difficult. I'd give it a high 6 low 7. This is the gatekeeper. It is a scatter of rocks that gives 3 lines. The only line I have tried on it is the left.
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_091906
The next really tough obstacle is a large rock on the left with a double rock stack that sucks you uphill into a side lean position. This is a spot where being short makes it easy.
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_094700
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. trail 30
It took some work to get the moar door Rubicon through. He envied my removable flares as we were trying to keep his from getting crushed.
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_095030 (1)
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_095146 (1)
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_095304 (1)
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_095215 (1)
We turned onto 31 and started immediately climbing to the top.
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_091120 (1)
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_101549
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_101446
Of course the pictures do not do the climb justice. This ledge was deceptively tricky.
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_100632
I heated up my tires to climb up this section with multiple rocks jutting from the wet clay. Long wheelbase ruled this area and before it was over I had to winch. I could have kept with the skinny pedal, but I was already making the trail less passable. I decided to save the terrain and equipment and use the add on.
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_101402
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_101359
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_101935 (1)
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_103017
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_104621
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_104623
The climb continues from there to the top.
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_102802
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_102805
Jason had a tag along.
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_164347 (1)
This is on 88 Jason and Mike posed as we looked around.
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_132327
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_132246
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. trail 88
Jasons second rider near the end of the day,
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_174418 (1)
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_101446 (1)
Valhalla
Valhalla
Valhalla
Chattanooga Tn
These are a hard line on 11.
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_113731
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_113736
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_113758
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_113802
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_113807
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120644
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120647
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120631
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120606
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120624
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120626
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120702
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120715
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120718
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120720
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120743
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120744
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120754
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120858
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120950
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_120954
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121000
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121006
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121127
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121129
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121138
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121152
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121232
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121245
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121303
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121313
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121322
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121325
Ford Bronco 8-2-25 Windrock Dawg daze dust run; turned out to be a cool rainy day. 20250802_121505
All in all, we ran 30, 31, 8, G1, 11, 88, 60, 53, 52, 72. It was around 30 miles of trails.
vrtical
Doug AI
GSMNP, TN
Fords
looks like I missed some fun stuff.
Jdyount
Kansas
2021 Badlands
Unless you know Windrock really well, I wouldn't advise going without some decent rock rails. One wrong trail and you would have wiped out your doors. Especially when it's wet.
Valhalla
Valhalla
Valhalla
Chattanooga Tn
It was a great ride, I'll try to get more up at work tonight as it is a non-production day.
Valhalla
Valhalla
Valhalla
Chattanooga Tn
I've been going there since the 90's when they first decided to turn it into a park. You are not wrong. It is a know your limits kind of place.
VirginiaHeritage
Frank
‘25 Bronco HE
I might get crap for this but my eyes got a little moist when I saw that silver Tacoma. Not even kidding.
The times we had before I had to put her down for frame cancer….
vrtical
Doug AI
GSMNP, TN
Fords
That Tacoma does better than my braptor and its on smaller tires except for the weld diff he has lol
Bikeric
Tulsa
2022 Badlands LUX on 37's
We started on trail thirty, it is rated difficult. I'd give it a high6 low 7. This is at the gatekeeper. It is a scatter of rocks that gives 3 lines. The only line I have tried on it is the left.
No Winch cable, to All the Winch Cable.
Story Please..... 🍿🍿
Valhalla
Valhalla
Valhalla
Chattanooga Tn
NoloBronco
Nolensville Tn
2022 Bronco Badlands SAS
100%. I needed up on 11 not know what I was getting into. Made it out ok but was nervous as hell the whole time.
