Windrock Broncos
Broncos that are running Windrock Off-Road Adventure Park TN
Valhalla
The run is on the event page.... here it is as well. I set it starting at 9 this time so the sun will be up.
KnoxGnater
KnoxGnater
Nice. What’s the max difficulty on this route? Potential trail rash? Winch needed? Air down to??
865Bronco
865Bronco
@KnoxGnater 22, 26 and 27 which are the first listed are moderate. Unless it’s very wet 22 is pretty simple, 26 has/had (one or two spots up top that were tricky but should be good long as you go slow) 27 is pretty simple. All of these here you’d be fine without a winch, or at least should be. I’ve done all of these solo numerous times, well besides 26 I’ve only done a couple times. Trail rash if any on these should be limited to possibly wheel rash, but I’m sure if you’re careful you would be alright.
Valhalla
Valhalla
Valhalla
Valhalla
Hey Rob, do you think I can make 82 since we were able to get up on Waldens ridge (of course I had axle failure).
Reactions: 865Bronco
865Bronco
865Bronco
@Valhalla I’m sure you could, you don’t mind pushing it further than I’m comfortable doing🤣
vrtical
vrtical
26 has two obstacles that are a challenge but 33s have done it with good spotting
vrtical
vrtical
Btw I am putting collars on and it's clicking my ass on the fronts lol
Valhalla
Valhalla
@vrtical I was curious why? are you going larger tires? maybe wider? Do they make rockmonster wheels for that? You need those and this!!!
vrtical
vrtical
@Valhalla so I don't blow the flares off again. I finished it netted me 2" in the front and 5/8 in the rear and it's completely level now no nose rake.
865Bronco
865Bronco
Hate to say I paid a shop to put mine on. Didn’t seem it would be fun in the garage floor. Well worth the couple hours labor and they can safely compress the spring and I don’t risk shooting a spring through the side of my head🤣
