HABO - Houston Area Bronco Owners
Group for the Houston area members!
Mkass
Has anyone gone to hidden trails adventure park in Marble falls? if so how was it ? going up late sept
Reactions: 4avor8ntfair
SpringTXOR
SpringTXOR
Awesome! I am going to go sometime when it cools off a little again.
4avor8ntfair
4avor8ntfair
Yes, it’s great!
Mkass
Mkass
Did you start off on the easy course first ?
Reactions: SpringTXOR
4avor8ntfair
4avor8ntfair
@Mkass did you do the Off Roadeo yet? Your comfort level will definitely change after one of those. At HF, There’s fire roads that are mostly easy, with bypasses around harder areas
Mkass
Mkass
@4avor8ntfair near did off road rodeo. Never been off road. Only time I’ve had engage 4x4 was 1980 plowing snow
4avor8ntfair
4avor8ntfair
@Mkass ok, if you purchased new and are eligible, I’d strongly recommend the off-roadeo. There’s one in Austin if you can’t afford the trip or travel time to go to one of the others…my buddy didn’t have the time to go to Moab like I did, but he still loved the Austin off-roadeo!
SpringTXOR
SpringTXOR
There are lots of warning signs if it is going to be a dangerous without experience/equipment, off rodeo does instill a ton of confidence in what even a base bronco can do.
Mkass
Mkass
Krak-A-Pat
Krak-A-Pat
@Mkass A year later I'm sure you have already gone, but... strongly recommend finding someone else if not a group to go with you. Hidden falls is a blast! If you haven't gone but want to go, let me know I'll def go. I have a 2" spacer lift and 34" Mickey Baja AT's I was able to do prettttty much everything to some extent. Also I only have rear lockers. so I'm sure your wild stallion will be more than capable. Key point here though, is ALWAYS wheel with someone, very least have a passenger to help spot for you.
SpringTXOR
SpringTXOR
I plan sometime July 4th or 5th to go.
