BASE BRONCO CLUB
Base model owners can share their builds, ask questions, and discuss common issues.
I put 33s on my base bronco a year ago. I’m wanting to get it lifted and still debating between a 2 inch lift and a 4 inch lift. Would 33s look too small on a 4 inch lift kit? Down to road I’ll probably get 35s eventually as well. Any thoughts would be helpful.
jrod5k
jrod5k
2” should be sufficient for now as well as 35s
Wark
Wark
A picture would help. Are you still running stock base wheels? True 33s like 255/85R16 (33.1"), or wider 285/75/R16 (32.7")? The tire width and the offset of your wheels will make a difference with the amount of lift, but I agree with jrod5k, 2" should be sufficient for 35s, unless you want to spend (a lot) more for the look and capability.
Reactions: jrod5k
