Tampa Bay Area Bronco Club
Bronco fan club to support each other with info as it comes out.
Has anyone been to the Croom wildlife management area(WMA) in brooksville? Looks like some decent light stuff. Looks like basically you need 4 wheel drive but nothing remotely crazy. Seems like a great first test to basically get dirt and mud on the tires.
SwampCactus
SwampCactus
Yeah and then Citrus Wildlife just across from it is even more technical.
BuckeyeBen71
BuckeyeBen71
Both are fun. Probably very dry at this time but lots of puddles once the summer hits.
vbrad26
vbrad26
Overall Croom is easy. Right now, with as dry as it is, it could probably be done in all 2wd honestly.
It can get a little tight in spots where you may get some branches running down the top/sides.
But other than that it is very low risk.
Citrus is a little more technical, however I've seen they have filled in some of the technical spots. But over time, they will come back...
Either would be fine for your first time out, but Croom would definitely be more mild.
