Upgrades, malfunctions & suggestions
GCC88
I had to re boot my system yesterday due to screen not turning off. Basically you start your engine stay in park - hold the power button on your radio & then the fast forward button until the screen shuts off & reopens. Next turn your Bronco off and then restart Bronco. Hopefully this doesn’t continue regularly as I’ll have to take it in.
Reactions: jrollo7
GCC88
GCC88
Anyone doing a hood decal, or replacing the black diamond emblem?
woof
woof
I moved the black diamond emblem towards the bottom. They hockey sticks extend across the top of the hood as well. Found them on extreme terrain for a great price.
Matador
Did you remember to do the voodoo dance around the bronco?, that should make the fix last longer.
GCC88
GCC88
That looks awesome btw!! Did you use a heat gun to replace & remove Black Diamond?
woof
woof
Sorry, just saw this. I used a hair dryer, it didn't take too much heat and I was careful to peel slowly and as far across the decal that I could to avoid stretching it or causing bubble like issues. But I did find a vendor whom sold replacements if I hosed it up, they were about $70 each
Reactions: GCC88
GCC88
GCC88
Wow! 70$a piece!! I’m removing mine in a day or two and wanted to relocate! I’ll definitely take your recommendations!!
GCC88
GCC88
It’s okay! Wow 70$!!! I’m about to remove mine and I like your re placement! Might do that or get another thought!!
Reactions: woof
Gazza
Gazza
Mine came off easy with a little heat. I put them on wax paper to hold onto them. @woof, I like where you placed yours. Looks great!
woof
woof
@Gazza Thanks, so as usual it takes me a month to notice this and respond, sorry. I think the only change I would make is to move the bronco emblem down and over by about an inch as others have. I also wasn't sure about the color. The stainless 'finish' was supposed to match the beauty rings on the rims, my other option was white to match the hockey stripes I had put on.
Reactions: Gazza
