rws
Greetings Georgia Bronco members!
I'm considering a color change for my Wildtrak wheel beauty rings. Thinking power coating is the way to go. I'd greatly appreciate hearing your thoughts / experiences and recommendations for places to get power coating done.
Billnchristy
Billnchristy
If you've read around on the forums be super careful with the bolts, apparently a lot are cross threaded from the factory and take an act of god to get off.
I used to use a little go-kart shop for my powder coat projects, it was in Lawrenceville, not even sure they're still in business, but a lot of bike, go-kart, off road places do it since they deal with a lot of tube.
Reactions: GABroncin and rws
rws
rws
@Billnchristy yes, I've seen quite a few posts about those bolts, which is a factor as I consider this color change. I'm up in the Acworth area, so looking for a shop / service on this side of the state. But will check with the shops as you suggested. There are quite a few around me from Marietta to Cartersville. :)
cpmartin1999
i removed the rings, no issues getting them on or off and im not any kind of expert. If you search powder coating on maps a few shops will show up near you for sure because i had a couple show up and one was even in Vila Rica, got them painted for $35 each. turned out nice, went black.
Reactions: rws
rws
rws
@cpmartin1999 awesome! thanks... $35 is cheaper than I was guess... heck, that's a no brainer if they can get me the color I'm looking at. :)
