2.0 top replacement today. It is noticeably better than 1.0. Hopefully the seals and “rattles” that slowly creep in (until you clean all the seals with silicon, again) won’t be a problem anymore. Downside, I have to a one careful with this one 🤞🏽
It came with windows? Shouldn't they be tinted? Maybe they are, just don't appear that way.
DasQball
DasQball
Wow, I thought this would have happened for you a long time ago.
I intentionally waited (the dealer suggested it) until they had run through the process for a while. My top was pretty good overall (minor snakeskin and occasional rear window leak) so it wasn’t a burning issue. Plus, I could scratch it up for a year without worrying!
ArrickSports
ArrickSports
;-) see, at this point I will end up with MIC 4.5 so it should be even better :)
That’s a good perspective!
‘21OBX
‘21OBX
What dealer can they sell the old one 😄
They have to cut them up and document the destruction in photos.
MontyMoose
MontyMoose
My 2.0 is doing well. It was installed back in April. Didn't have any real issues with the top that came with it other than some of the rear defogger lines being damaged from the factory (replaced under warranty), and a slight slight squeak/rattle from the driver's side panel that developed after 3 months.
The squeak/rattle is non-existent now, though I suspect that's because the latches on the new one were much tighter than the original (actually had to loosen several of them up).
I have noticed the fit and sealing of the 2.0 is much better. The liner is better, really an improvement in every area (my 1.0 wasn’t bad either). I would be completely satisfied if the top didn’t have several small scratches from shipping 👎🏽
