BigDeal
So a question to the group. My Wildtrak came with about 49psi in the tires from the dealer. The door sticker is saying to run with 39psi. What is correct? I have the stock 35's that come with the Sasquatch package. I put about 700 miles on her all ready and it rides great, just don't want to wear the tires prematurely by running at too high a tire pressure.
Bdockins
Bdockins
40 is my sweet spot.
Nick72
Nick72
Mine came from the dealer with 43 to 45 lbs. It seemed to ride a little rough, so I dropped them down to 39 and it rides much better.
Haven't noticed any uneven tire wear.
BTomorama
BTomorama
Dealers always seem to over inflate new cars. Not sure if it's to prevent deformation with them sitting for so long (oh hey dirt mountain!) or what.
Definitely go by what the tires say.
DREWR13
DREWR13
same as above around 39-40 for mine
Peter Gosenya
Peter Gosenya
Tire pressure is determined by weight on tire then adjust down for comfort. The pressure on the sidewall is for the max weight rating of the tire. If you’re not close to that then you don’t need that much pressure.
