Maryland Bronco Club
A group for Bronco lovers across the great state of Maryland.
Tents+Tread
Is anyone good with wiring? I need to wire up 5 LP9s on the Roof of the bronco and will require so help for sure!
The Rack Boss
The Rack Boss
Easy do you have up lifters?
Tents+Tread
Tents+Tread
@The Rack Boss yes the upfitter switches but that wire is WAY to thin for the power coming to an LP9. Will need to run lights to a few relays or solenoid then to the upfitter switch box to avoid popping fuse
The Rack Boss
The Rack Boss
I just put the Baja Designs XL Linkable Light Bar 8 XL on with no issues. Thought they were like mine. NOPE did you get a LP6, LP9, Upfitter Lock Out Harness
The Rack Boss
The Rack Boss
The 8xl are so bright you think it is daylight out. You can see particles in the air driving down the road at 60
Tents+Tread
Tents+Tread
@The Rack Boss ya I already had the LP9s so just transferring them but on the old build they had to be run through 4 relays
