Bay Area Broncos
Here we go with the new G.O.A.T’s of the bay!!
BLMike
Knoxville OHV Adventure or "The break in of the Bronco"
Thursday my friend and I decided to do a boondoggle (aka playing hooky) and took my Bronco for her first day off-road. Here is a summary of our trip. We used my friends Gaia app to record the trip.
It is about a 2 hour drive from Walnut Creek and we went via Lake Berryessa. It was a nice drive but there is still a lot of fire damage that you can see. Slightly after the lake, the two lane road really turns into a country road with a lot of pot holes and some stream crossings. The stream crossings have a concrete base and I bet can be quite large if there is a lot of rain. There was water but not much.
We drove past the south entrance a bit just to check it out and then looped back to go in on the south entrance and out of the north entrance. Drove up a small hill and aired down. Make sure you have a good air compressor. I have this one from Viair https://www.viaircorp.com/portables/400p-auto Aired down to 20 psi via gauge on compressor but car TPMS said 23-25. I usually like to go lower around 18 but didn't think it necessary.
I think this is a good starter trail. One of the reasons we wanted to do it was to flesh out the Bronco and not have too much of a challenge her first time out. The route we took has enough challenges that those new to off-roading will have fun but still need to think and plan your line. Just take it slow and easy when you meet a challenge for you and your Bronco will perform well. In the beginning of the trail I was in 2H. However, I did switch to 4H eventually. I also wanted to make sure the Bronco didn't have any issues so I also tried all the features (hero switches and trail "cruise control") and everything worked fine. There are some open areas where you can push the Bronco a little faster and that was fun. Of course, the terrain can change because of weather so this is no guarantee there won't be more or less challenges on the route we took. Read...do it at your own risk.
Below is a screenshot of the route we took with some info. I hope you find it useful. Please, PLEASE! note the upper part of the map where it says to stay to the right. Do it. Do NOT go the red route! Knoxville OHV doesn't rate their trails like other OHV parks. Green for easy, blue moderate, etc. The trail up to the point of the fork in the road had been relatively easy for us. We decided to go left, over the hill. Everything was fine till we got to the top. Lets just say it was the most challenging descent either one of us had ever taken. It required a lot of spotting and finesse. Probably took an hour to get down and I am amazed, AMAZED Gigi (that is my Bronco) made it out unscathed. Hind sight we should have turned around at the top, but it was also very exhilarating in both a good and bad way. The kicker though...the junction where it meets the other trail around the hill was ROPED OFF! What!? Uhhh..no sign, nothing indicating this from the other direction. Luckily we were able to go around the obstacle. After that we had to take a breath and check our pants. All good. Then we noticed...1000.0 mile mark. She is broken in! :)
Useful links:
Knoxville BLM website https://www.blm.gov/visit/knoxville
Our route via Gaia https://www.gaiagps.com/public/AYIXL6SPm6oFCnVExqNiJj4C/?layer=GaiaTopoRasterMeters&slideshow=false
Here is a link to the .gpx file of the route https://www.dropbox.com/s/x2o04jds8vvsmi8/The_break_in_of_the_Bronco.gpx?dl=0
Here is a link to a free online .gpx viewer https://www.viewgpx.com
Hope you find this post useful.
Our Route:
BLMike
BLMike
I would like to add that our experience at the Vegas Off-Roadeo really helped understand the tools my Bronco has for us to use when off-roading. I highly recommend attending one if you can.
Daktari
Daktari
nice write up, thanks for sharing! Sounds like worth exploring, not too far away.
Reactions: BLMike
titleistforged
titleistforged
Thanks for the exhaustive write up! As I'm new to offroading, sounds like having an air compressor is a must?
Reactions: BLMike
Daktari
Daktari
@titleistforged I would say so, I'm pretty new to it too, took my Taco offroad here and there, but nothing extreme. Not that I plan for extreme.
I bought the Viair 450P: https://www.amazon.com/gp/product/B000X9EGFS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Used it over xmas down south in the Anza Borrego park. Works very well, I like that it shuts off by itself between tires. Cheaper than ARB (I'm pretty sure they charge extra for each letter in their name) and aired me back up pretty fast. ARB dual will be faster, but since I don't live anywhere near trails to hit every weekend I figured I can wait a couple more minutes. Comes in a nice bag.
Airing down definitely made for a nicer ride, I went in first at full PSI. The trails we drove did not really need it for grip though, but that comes in on rocks and sand etc.
Get a good one, not the little ones you plug into the lighter outlet. Mine goes directly to the battery and you leave the engine running.
BLMike
BLMike
@Daktari I have the same compressor. Linked to manufacturer’s website in original post. Comes in handy when airing down too. The gun with the gauge that is.
BLMike
BLMike
@titleistforged Shop around. I got mine around $270 if memory serves me. Yes it is an important tool to have.
Corsair
Corsair
Planning on heading up there tomorrow morning, thank you for the write up.
BLMike
BLMike
@Corsair Yep. Our hearts sank when we saw the rope. My biggest concern was scraping the side on that off camber part at the end. I had my sway bar disconnected and was hoping that would help keep me away from the wall. I was also hoping the upper rut would help too. From above going down into the off camber part it looks like it really drops off. But getting out and looking relieved that stress.
Corsair
Corsair
@BLMike For sure, though getting out of there was the biggest stress relief lol. Not looking to do anything quite that sketch for awhile though.
BLMike
BLMike
@Corsair We wanted to take a nap afterwards! Yes! Got that out of my system for a while. :)
