Leonardtown Ford Reservation Holders
Leonardtown Reservation Holders
NayNay
I am going to try and keep up with posting these. They are important if you are trying to track the potential of hitting the lottery and having your build pulled. I do not mind making changes as these come out. If a small tweak here and there can help your build to be pulled faster that is great!! These can and probably will differ month to month.
RDS12
RDS12
I see my entire build is still a constraint 😅
BPMANAZ
The irony is that at the rate the sleazy developers in Virginia are building shitty houses on every square inch of land there is....by the time (if the universe has enough time for FORD to get it's act in order) that my Bronco gets built, the only off-roading around here will be the median strips between the overcrowded highways.
Eharris55
Eharris55
@NayNay, what do the regional numbers mean for us? It’s seems like the national commodity continue to grow unfortunately.
NayNay
NayNay
Sheesh, you forced me to do work. Shame on ya!! LOL So according to what I am told if what we want (for us the Bronco) has restrictions in both our region and national that is like a double slam. If we have no restrictions in our region (currently we do not) then we look to national to see the Bronco. There (using hard top MIC as the example) there is 52% and it is indicating to us that it will vary by dealer. Meaning that 52% will get spread over the nation. Some dealers may get 1 built and some nothing. So, if you elected paint film protection you are not being built anytime soon. Any 2 doors with E5A, E5C and E5F are also pretty much out of luck this next lottery drawing too.
Reactions: RDS12
Eharris55
Eharris55
Thanks so much for that explanation. 2023 can’t get here soon enough lol. I’ll send you a text with an adjustment to my build. I No longer need the tow package.
Reactions: NayNay
NayNay
NayNay
ok
