broncoGIRL21
How is everyone dealing with rock chips? I went down a dirt road for the first time yesterday and I have like 4-5 rock chips already on both sides of the car. I don't have mud flaps because I didn't think I would like the look of them. What do you off-roaders do?
  • Wow
Reactions: Broncogirl66
ArrickSports
ArrickSports
;-) by the time I get mine y'all will have this figured out
LadyBronco
LadyBronco
I’m considering the OEM mudflaps myself (when my Bronco gets here next month) I will have the steps too so that should help…hopefully?
etmccaus86
etmccaus86
What do you hate the look of more - mud flaps or paint chips?
I'm probably doing flaps and running boards.
broncoGIRL21
broncoGIRL21
Great question. I definitely had the paint chips. Mud flaps it is, I guess. Don't think I can do the running boards, though. Although as the paint chips mount, I might change my mind on that as well. Are these paint chips going to rust?
I believe everything but the rear quarter panels are aluminum, so should not.
MontyMoose
MontyMoose
I'm waiting for some mudflaps that accommodate the Sasquatch flares AND running boards without having to finagle a DIY solution, let alone one they're charging $500 a pair for.
IGOAT2drBD
IGOAT2drBD
I have sas and had a bunch of stone chips before I figured it out as well. So I got the mud flaps that go with sas pkg and I do like them. BUT I also did a clear vinyl strip all the way up and down the body right up the crease in the door. It is almost impossible to see and it's worked great for me so far.
Reactions: Mattwings
broncoGIRL21
broncoGIRL21
@IGOAT2drBD Oh, that's a great idea. How would one do a vinyl strip? :)
IGOAT2drBD
IGOAT2drBD
@broncoGIRL21 I had it professionally done. Most shops who do vinyl or graphics should be able to help you out. My 2 door cost a couple hundred out the door. I used a guy south of Ann arbor if your near by I can get you his contact information.
734Bronco
@IGOAT2drBD please share his contact information with me as well.
cwhite
cwhite
@IGOAT2drBD - can you share the Ann Arbor shop you used for the clear wrap? Thx!
