I was in Plymouth yesterday and ended up in a line of three "Big" Broncos. The deliveries are happening at a much higher rate now! Hopefully the group keeps adding Broncos to our collectives stable!
I have only seen 1 ever on the road, and that was early this spring in Houghton Lake. The only other ones I have seen are dealer demos. So not many deliveries making their way up to northern MI...
DasQball
DasQball
I can only hope.
JakeC
JakeC
Starting to see a few of them out and around the metro Detroit area now.
Detroit0486
Detroit0486
If they ever get a bunch of us off of dirt mountain we will see a lot more soon, fingers crossed!
Nite93
MAP is replacing about 150 tops between both shifts 7 days a week. About 1k a week. Sadly, MAP isn't even running 8hrs of production per shift currently.
Nite93
Webasto still can't ramp up fast enough
BroncoAW
BroncoAW
If one was white, that could have been me
I think the first in line was white, the one right in front was CG, same as mine (just not BL or SQ, not sure what trim level). Today and tomorrow might be the last top off days for a while!
I’m headed to Las Vegas for next week, then up north for the weekend, hopefully stay warm and dry enough.
etmccaus86
etmccaus86
Saw 3 in the span of 20 minutes in Howell/ Brighton area today. The Outer Banks 2-door was probably the oddest-spec'ed example...
