Pittsburgh/Tri-State Bronco Club
Your home for the Yinzer's Bronco Club!
PittShawn
Just FYI, it appears that people are showing updates in Ford Tracking even without receiving emails. I had a 8/9 week production, and when I just checked it shows it's currently in production. I haven't received any emails or window sticker(gives a message to check back soon). So, if you are lucky enough to have a VIN and build date projection, worth checking Ford site periodically. Or if you're like me, every few hours!
Reactions: Lothbrok
Rubisquatch
Rubisquatch
Mine was built on 7/21, same thing. You only get a Ford email when you get scheduled with your Vin and then another (sometimes as not everyone is getting this one) when it’s ‘built’ - and built means it’s cleared QC and shipping is likely in progress. There are no emails when you move ‘into production’, the only thing that happens is the tracker changes like what you reference above. And you usually move into production about 7-8 days before your blend date.
Reactions: OJ_Loose
OJ_Loose
OJ_Loose
@Rubisquatch Found this thread in the search. I too had 8/9 week. Just got the window sticker today and blend date is 8/10. I guess its a good sign!
PittShawn
PittShawn
Fantastic to hear, thanks! Blend date says 8/10 which now makes more sense.
KareBear
KareBear
If the order tracker says “In Production”, but your window sticker isn’t available yet, try the Bronco6G order tracker. Mine showed up there, while the Ford one was still pending.
