ARIZONA Bronco Club
Arizona club designed to hold possible outings and get togethers in various places around AZ. BBQ's, Saturday group meets, coffee and cars morning, drag racing...jk but maybe?
Reich480
Wanting answers from fellow bronco owners. Sorry don't do social media much, so have to post here. I've read more articles than I can count on the subject I'm about to ask a question about, but would like to hear from anyone who's done this.
I have a 2024 2door badlands Sasquatch. I replaced the beadlock capable rims, for some 17x8.5 mayhem rims, 0 offset.(7lbs lighter each) I've added a 2in zone offroad level with new upper control arms. Also added the JKS max tire clearance kit, so no more crash bar horns and wheel liner pulled back about an inch or so behind front tire. Most Rock crawling I've done is the waterfall at box canyon near Florence,AZ
Has anyone gone to larger tires than the factory 34.5? Originally was going to get 37x12.50r17 KO2, which are actually lighter in weight vs the 35x12.50r17, go figure. I have a local shop that can do forscan to adjust speedometer, unlock goat modes(sport) lower tpms, double honk ect... My setup should clear the tires, worried about fender clearance, especially once sway bar is disconnected. So torn between staying with "35's" or getting 37's (36.5)
Any one on here go the 37 route or stay with 35?
Ty in advance, and apologies for asking a question that's been asked countless times. Thanks
Brandon113
Brandon113
Could always get the fender deletes if you are okay with that look
Reich480
Reich480
@Brandon113 thought about ADV fiberglass fenders, but trying to not spend a fortune just to clear 37's. A 1-1.5 in body lift would be the cheapest option, but really dislike the body gap of anything over 1/2 inch
Brandon113
Brandon113
I have seen some posts depending on brand that Sasquatch can fit 37s
Brandon113
Brandon113
I was thinking on mine do do a 2-1/2 lift with 37s
Reich480
Reich480
@Brandon113 I have a total lift of 3.2 in +/-. The BFG ko2 will fit without rubbing, just worried about articulation once Rock crawling. Could install bump stops i guess. Tha ks for your feed back
Reich480
Reich480
Update: so after everything to fit 37's, I decided to stay with 35's for now. Unfortunately I'm on pavement more as of late, and cons were more than pros. Getting my 35's installed tomorrow. Falken wildpeak at4w 35x12.50r17
Reactions: Brandon113
dangerfoot
dangerfoot
Winds of Change
Winds of Change
@Reich480 I also have the Falken Wildpeak AT4W on my Sas. do they ride a little rough for youy? I can feel the tread on the pavement when driving. Everyone states how smooth they are. I feel they are not as smooth as everyone states. Is it me Or the tires? 315/70/17 OE size and pressure.
Reich480
Reich480
Normally there would be a button for me to click on my photos but it's not coming up. How do I add photos. Android phone.
