Bronco Gals
Fine adventurous ladies (and that includes soccer moms!)
Walnut
I promised to share quotes from a paint shop for the MIC top.
My plan is to have the top "dipped" which is a plastidip type product. It's a rubbery-like spray that protects your surface while giving a different look depending on the color you choose. And it's easily removable when you want to change up the look. The texture of the MIC top will still be visible.
Plastidip (low end product, more rubbery feel)
-Top $400; grille $129
Proline (better durability and smoother feel product)
-Top $800; (don't remember grille quote)
Autoflex (feels just like clear coat and protects paint from scratches)
- Body of vehicle, minus top & grille $3500
I recommend these products over a vinyl wrap. Vinyl can leave a residue and will be a more expensive installation. You can check out dipyourcar.com for the products and follow @Fonzie on IG. I've been following these products for years and I use plastidip for craft projects
sjp
sjp
Great info! I'm toying with the idea of having my AMB 2-door Base's top and grille painted white. Maybe the wheels too. Not sure about the flares, but I may get them painted in a color as close to the AMB body as I can. Plastidip may be the way to go. That photo of Leno's old Bronco is my inspiration.
Reactions: Walnut
Calicorks
Calicorks
I used plastidip on the rims of my 2001 Mini Cooper S manual. Looked great, and when I sold it I took it off to be stock. I do miss that Mini.... ?
