Outer Banks Club
Join if you ordered an Outer Banks!
errejerre
Toyo RT 275/70 R18
RTR Wheels 18” +30 Offset
PatsBronco
PatsBronco
Very nice!
BigBlueOBX
BigBlueOBX
Awesome! Looks great in white.
Rocktight
Do you have any more pics of this setup? From the side and is there any poke at all? Looking at almost the exact same setup. Looks really good in this pic!!
Mace
Mace
@errejerre I see lots of OBX owners going with that tire size. Any mods or is that stock height? Also, any impact on the speedometer?
BigBlueOBX
BigBlueOBX
My Speedo was showing 70mph when I was actually doing 74 mph monitoring with Waze and Escort Radar GPS readings. Yesterday I installed Rough Country Speedometer Calibration module and programmed compensation calculations. RC did not have a good link to show installation process on the Bronco. I did find Hyper-tech had a video on YouTube showing step by step on how to install the same type of device. If you follow Hyper-Tech install video be careful at step 11c removing the panel with the start/stop switch. Once you remove the screws there are 6 retainer clips holding the panel in place. Clips 4 and 5 counting from left to right actually are notched and you need to slide the panel to the right once you have pulled the left side and far right loose. I test drove the vehicle before putting it all back together. Had to reset calibration several times to get the correct compensation set.
