What changes have you made to your Bronco using ForScan?
SevenT
1970 U15 Sport Edition; 2021 AMB 4 Door Badlands
I guess I’m confused. You have a Sasquatch Badlands that comes with the 4.7 gear ratio, correct? The non-Sasquatch has 4.46 (as does my Black Diamond).
What exactly did you change in Forscan?
I got a non-Sasquatch Badlands to get it in Antimatter Blue. It comes with the same axles as Sasquatch but with 4.46 gears. I did what I call 'MySquatch', i.e. lift, 35s to starts and then 37s and a 3 inch Icon lift. The finishing touch was to add 4.7s to the FDU and M220. I needed to change the gear ratio in the BdyCM and relearn the PCM and AWD modules. Speed is accurate.
Smitty1979
Glens Falls
1968 F-100, 2016 F150, 2021 Bronco sport
I have a 2022 4 door Black Diamond non sasquatch 2.7. I added the Eibach stage 2 coiler overs 3 inch lift, 37x12 50x17 bf goodrich all terrains. Should I adjust a setting for the axles? If so how would I do that? I'm getting the cable tomorrow and need to change tire size from stock 265 70 17 (32) to the 36.5 BF Goodrich. Only other thing I'm going to do so far is adjust roll bar speaker outputs.
Thanks in advance
SevenT
Thanks in advance
You will need to change the tire diameter in the BdyCM module to 2791 mm, then relearn the PCM to get your speedometer correct for the tire size change.
Smitty1979
Glens Falls
Thanks in ad
What was your purpose of changing your gear ratio to 4.7? Did you change the gears or did you do it to trick the computer? If so should I do that as well or just the tire size amd relearn? I had the abs noise last night near brake pedal inside the vehicle at 10 mph or less after 600 miles with lift and 37's...
SevenT
Thanks in ad
Sasquatch came with the 4.7 gear ratio and running 37s I wanted better MPGs. I went from the high 15s with the 4.46 to mid to high 16s with the 4.7. Personal choice I guess.
Smitty1979
Glens Falls
Did you actually change the gears or just tricked the computer?
SevenT
ejaffe
New Jersey
Audi TT
what is the code change to allow the fog lights on when the bright lights are on?
timhood
Tim
Several
I didn't know that was a thing. That's against FMVSS.
timhood
Tim
Several
Use at your own discretion. :)
BdyCM726-39-02xx**xxxxxx--Front Fog With High Beams: 00=Enable 01=Disable (option)
ejaffe
New Jersey
Audi TT
You rock! thank you. BTW, since the bright lights automatically dim when there is oncoming traffic, I am not so concerned about both being on at the same time blinding oncoming drivers.
RideClimbNJ
NJ
23Wildtrak
I turned off the double honk when you get out with the keys and enabled windows down and windows up from the FOB. Both are GREAT.
Where are the settings for windows up and down from the FOB? Didn’t see them in the Forscan spreadsheet.
