- Nate
- Jul 14, 2020
- 55
- 2,712
- 5,909
- Sac-a-tomatoes
- Bronco, F150
- Black Diamond
Hope to put everything in one place for what we know about spacers lifts. This is an update to what was previously thought since we are now a couple of years in.
We have the cv axle thread and travel here if you want aftermarket shocks!
https://www.bronco6g.com/forum/threads/some-stock-suspension-calculations-and-measurements.73917/
Front Differential thread here (cv axle comparison inside)
https://www.bronco6g.com/forum/threads/front-differential-discussion.79723/
SAS-Bronco's/Broncos with a factory front locker
What we have learned, you can add a 1" spacer (1.6" of physical lift) to SAS-Shock and be in the safe zone. This means your fine running all Zone lift and Icon spacer lift on a SAS-Bronco. The rest of the lift has to come from collar or spring side spacer. SAS-Bronco has a physically bigger cv axle with deeper cups allowing for safe operation. Once you exceed this you should be carrying spare cv-axles.
NON-SAS Bronco(every bronco that doesn't have a front locker)
You can run a 1.4" spacer (2" of physical lift) you however are not in the safe zone! The smaller cv axles are nearing over extension and tend to have the issues(internal moving parts can touch the retaining ring causing it to come loose and poke a hole in the cv-boot). Almost all the manufactures are providing this 2" of physical in the form of a spacer, a certain percentage will have issues. Safe zone for the stock Hitachi shocks is actual in the 1" spacer area(1.6" of physical lift) this is more in line with a leveling kit like Zone or Rough Country. This is where the ICON 3" lift is a good option if you want more lift, it comes with a 1" spacer and a spring spacer.
Facts
Spacer lift will increase your CV-Axle angles at ride height and at max droop. Both decrease the life of the CV-Axle and increase the chance of failure. The harder you wheel the more likely you will damage a cv-axle with a spacer lift.
Upper Control Arms
Upper control arms serve to purposes at this stage. One is to help with alignment and the other is to help pull the CV-Axle in a little(help get the lower a-arm adjuster back to a more normal setting). This is why most lifts recommended the control arms. Don't ask me which ones to buy as I am still trying to figure out which ones are worth the money. Upper Control arms are not required for this level of lift.
Footnote
I define safe as your not going to drastically increase your chances of failure. This is in line with what I would recommend without fear of retaliation and internet trolling in the future. My education has been my own person experience with M190, Hitachi's, 5100s and stacking spacers(I have had zone 1.4" pucks, zone 1" pucks and rough country leveling kit).
Facts
Upper Control Arms
Footnote
