Bruh…Are you using the alignment pin that Ford gives you? It looks like a little top and you screw it into the bottom hinge. Then, once you get it aligned, put the top bolt it, unscrew the alignment pin, put the bottom bolt in, done.
I'd imagine without the alignment pin, getting the doors back on would be hell. With the pin, it's super easy.
2yrs of owning this Bronco…
