- Jake
- Oct 22, 2021
- 448
- 1,001
- 718
- West Palm Beach, FL
- 2022 F-150 RCSB 5.0
- First Edition
JKS Manufacturing is NOW AVAILABLE at Lethal Performance!
Since 1989, JKS has been manufacturing some of the highest quality, most respected products for the Jeep aftermarket, but now, they are bringing their engineering talents to the Bronco aftermarket as well!
The Tie Rod Sleeve kit is a cheap, easy fix for the Bronco’s weak tie rod issue, which has been a popular problem on Sasquatch Bronco’s, (larger tires off-road = More strain)
The Max Tire Clearance kit is pretty much self explanatory, but essentially is to give more clearance to the front wheel-well to install larger tires on your stock height or lifted Bronco models!
*THIS KIT REQUIRES MODIFICATION TO THE VEHICLE’S FRAME, CHECK INSTRUCTIONS BEFORE PURCHASE*
Check out everything JKS in the link below!
https://bit.ly/3P6fUpg
