Big Bend and Base Grilles
StuRox
Stu
Chicago
Honda
Hi! Does anyone know if these grilles are interchangeable? I may be getting a BB but would like the Base Grille one day instead. Wonder if they can be ordered one day from Ford?
5280Bronco
Denver
Hi! Does anyone know if these grilles are interchangeable? I may be getting a Badlands but would like the Base or Black Diamond Grille one day instead. Wonder if they can be ordered one day from Ford?
Yes, they are interchangeable, and I'm sure they will be available sometime from Ford. You'll find them sooner from a forum member though i bet once everyone starts to take delivery of their broncos.
StuRox
StuRox
Stu
Chicago
Honda
Great news! Thanks for feedback!
uncledoodoo
Everglades
00 XJ, 56 F100, 11 Volvo XC90, Everglades
Everglades
could just paint the BL grille black if that's what you like. I do love the base grille though.
one800higgins
VW GTI
They may not be compatible due to the lighting differences. That said, the Wildtrack grill is similar to the base grill while housing the upgraded lights like the Badlands.
StuRox
StuRox
Stu
Chicago
Honda
Wonder if Base and Big Bend are identical in size, lighting configuration? Decided on BB and want Base Grille. Thanks!
iamchewby
Chewby
Haven't taken measurments but the fact that the BB is available with both the base lighting and the "signature" lighting tells me that the geometry of the lights are the same. Mounting points and grill size between trims won't differ. So, I think you'll be okay to change to whatever grill you want.
In the end, we're still in the beginning of all of this so it will take brave souls like yourself to test things out, but I don't anticipate grills to be a problem.
Contact
Randy
Austin, Texas
Bronco Big Bend. FJ Cruiser
There are discussions here and topics and videos online stating the grills are 100% interchangeable.
Papa Smurf
Jax, FL
ā€˜23 Bronco WT. ā€˜23 Maverick. Hybrid. '23 Rav4
From my understanding, the only limitation to swapping grills is the camera. Some have just the front, while those with High and Lux have the 360 cameras. It would be doubtful if I could put a Base grill on my OBX with High, so Iā€™m going WT and will paint it.
Contact
Randy
Austin, Texas
Install the camera in the new grill. I would think it's plug and play since you have to detach the wire harness to remove the grill
Papa Smurf
Jax, FL
There are 2 different WT grills based of number of cameras. Iā€™m not sure that the lower would have be holes for the higher trim.
StuRox
StuRox
Stu
Chicago
Honda
I don't think the Big Bend has a front camera, does it? My hope is to just order a Base Grille and just simply swap it out easily from my Big Bend grille with no camera or wiring modifications. Just unscrew and swap!
Papa Smurf
Jax, FL
Base to Big Bend you should be ok. Iā€™m thinking that all Broncos have the front camera/hole. You shouldnā€™t have to splice or cut wires but just unhook the camera and stick it back in the harness for the new one. All of this is best guess from what Iā€™ve read and watched so far.
Papa Smurf
Jax, FL
Make sure that you order the letters too. We are finding out that they are NOT included with the purchase of a new grill. @flip verified by opening a box.
