Wiring Oracle Triple Fog kit
Snowdogyyz
23 Ford Bronco Wildtrak
So I received this fog light kit from Oracle-
https://www.oraclelights.com/products/bronco-triple-fog-kit?_pos=1&_sid=d5d765c87&_ss=r
Obviously very simple to wire the whole thing to an aux switch. What I want to do is wire one light on each side to the fog light switch (I have Lux/mod bumper- wiring is there) and the other two per side to an aux switch. Anyone done this yet and has some pointers, wiring tips, etc? I assume I unplug one light per side from the existing fog light harness, wire those together and plug into the bronco fog harness at the bumper (then FORSCAN) but are there some plug adapters I need?
Then I would wire the remaining 4 lights- hots together to the aux wire and grounds together to a good grounding bolt somewhere. I’m in no way a wiring guru so any advice, tips, etc appreciated!
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
You answered your own question
in the post. You should have no issues. Good luck. I hooked my Oracle lights to Aux 1
Snowdogyyz
Snowdogyyz
I guess one thing I’m not sure about is- is there a connector that’ll work from the fog light to the fog light switch connector? The light wiring plugs into the exiting harness and couples with a screw on cap. You can unscrew and unplug one light from the light harness and leave the other two plugged in. Is there a conversion plug from the light to the fog light switch plug in the bumper?
Agrod
SJ, PR
22 4dr OBX
I didn't want to mess with custom wiring and used the original wiring direct to the battery as in the instructions. Instead of using the provided switch, I used aux switch 3 as the trigger wire on the relay (white cable). That way, the fogs turn on automatically when the engine is running and go off when off. I ran a single wire from aux switch 3 to the white trigger wire on the relay.
OnlyOnce
Ken
Pa
2023 Bronco
Is there a reason for using AUX 1 (25amp's)? I see most people post on here and in videos they are using AUX 1. I see the amp rating for the Oracle Triple LED is 3.6 and considering the possibility of using AUX 1 for a light bar (a month or two down the road), I would like to use the AUX 1 (10amp's) for the fog lamps. any cause for concern if i use 6 instead of one?
OracleLights
New Orleans, LA
Hi Steve!
You are definitely on track. You can purchase 6x of our 2 pin extension adapters. Doing so, you would then be able to plug one extension into each individual light on each side, then cut the other end off and strip the wires back. Then you would hard wire the 4 that you want together on one AUX switch and then the remaining 2 would be hard wired together to the other AUX switch. Also, keep in mind that AUX switches send power only so you would need to put all the grounds either to chassis or to battery negative. Feel free to give our tech team a call if you need further guidance!
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
One word of caution, even the fog's are very very bright and you'll probably get flashed for blinding other drivers. I put all min on the aux switches to make it easy to control them. YMMV.
KnoxGnater
Nat
Knoxville, TN
Nope. I did this very thing. I have lights on 4, 5, 6. Stickerfab sells great labels.
OnlyOnce
Ken
Pa
2023 Bronco
Thank You! I will use the lower end, and not the 25 and 15 amp..
BR549
Tennessee
22OBX, 23BD, 23Expedition, 05F150
@Snowdogyyz : Did you end up ordering/using the 2-pin extension wires per Oracle's suggestion? I recently did but the threads on the ext wire connectors are a different size than that on the fog light. Not much, only a mm or 2, but the caps will not screw on. So far, no resolution......
