Window dip on unlock
GRB1959
Gordon
Aurora, CO
2021 Ford Edge ST, 2024 Ford Bronco Badlands
This makes no sense, someone with a 2023 build date doesn't have it, someone with 4/24 build date doesn't have it, and I have a 1/24 date and I have it.
And why would Ford remove this feature?
I asked about settings, because I suspect it's the unlock all doors setting.
I just ran a quick test on my 2024 Badlands with a blend date of 01/11/2024 and it has the window drop feature when I unlock using the keyfob and also when I place my hand inside the door handle to open the door. It has worked this way since I took delivery of my Badlands on 02/01/2024.
Gord
Stevenson James
Chicago
2024 Bronco
My settings are to unlock the driver's door.
Hence, when I click the unlock on the fob, my driver's door unlocks and the window cracks. If I double click it, the passenger door also unlocks and cracks the window.
This is exactly how my '24 works. If i double click to unlock all 4 doors, all windows drop.
Maybe people just need to set their remote unlock for driver only and see if theres any difference?
bomchet
Bom
northern va
2014 dodge durango
I have my 22 Bronco in the shop today and I asked them to install this update -- and they said it only gives them an error so they didn't proceed. Really want this feature.
Blue Hen
Delaware
18 Suzuki Vstrom 650XT, 22 Bronco Base MT SAS
I had the window drop feature done on my 22 the last time I was in for service. Advisors didn't know what I was talking about. The tech working on my Bronco doing update on camera recall just ran the two window module update at the same time. No charge. I like the drop when hitting remote. It has a slight delay before dropping, also it stays dropped for about 10 to 15 seconds if the doors are not used.
