SuperPro Upper Control Arms - Now Available at Panda Motorworks!
Caleb@PandaMotorworks
Caleb
St Louis MO
Now available at pandamotorworks.com, the SuperPro Upper Control Arms!
If you're looking to elevate your Bronco's off-road capabilities and overall performance at a great price, then look no further than the SuperPro UCA! These control arms offer a number of features and benefits that make them a worthwhile investment, including,:
  • Improved Caster: Caster is the angle at which the steering axis tilts backward from the vertical. A proper caster angle is essential for proper tire wear and handling. SuperPro UCA are designed to increase caster, which can help to reduce tire wear and improve steering stability.
  • Increased Droop Travel: Droop travel is the amount of downward suspension travel that a vehicle can achieve. Increased droop travel can be beneficial for off-road driving, as it allows the tures to maintain contact with the ground over rough terrain. The SuperPro UCA are designed to increase droop travel, which can help to improve off-road performance.
  • Greaseable Ball Joints: The ball joints in the SuperPro UCA are greasable, which means that they can be easily lubricated to extend their lifespan. This is especially important for off-road driving, as ball joints can wear out quickly in dusty or muddy conditions.
  • Adjustable Design: SuperPro UCA are adjustable, which means that they can be fine-tuned to achieve the desired caster and droop travel settings. this allows for a more customized suspension setup.
  • Smooth On-Road Ride: These control arms not only excel off-road but also contribute to a smoother and more controlled on-road driving experience. Say goodbye to the jarring and uncomfortable rides associated with some aftermarket suspension components.
Other benefits include:
  • Improved tire wear
  • Increased steering stability
  • Improved off-road performance
  • Longer lifespan of ball joints
  • Customizable Suspension Setup
SuperPro Front Upper Control Arm Set Ford Bronco 2021-2023
Ford Bronco SuperPro Upper Control Arms - Now Available at Panda Motorworks! Screen Shot 2023-11-07 at 2.58.14 PM
Ford Bronco SuperPro Upper Control Arms - Now Available at Panda Motorworks! Screen Shot 2023-11-07 at 2.58.21 PM
