Step bar with rock rails
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
thank you! When you remove the RR's are their holes to fix?
No, but I still put a covering over the pinch weld to further protect it from rock chips etc before putting on the boards. I'd seen this idea on another thread on this site.
I attached a pic of the product I used.
Ford Bronco Step bar with rock rails 20211213_180537
Skidog
Sandy
Encinitas
Bronco "21"Badlands 4dr 2.7,"23"2Dr Man,Tesla, Bmw
Thank you. That’s amazing!
noliveaxle
john
Riverside, Calif
2015 jku rubicon
Those are from ZROADZ. I just ordered a set over the black Friday weekend (20% off) for my 2 door. I will post after I get them mounted.
Only picture I have.
Ford Bronco Step bar with rock rails 3CD0EE33-D3A5-4AEB-9B24-B60EEEFFE617
ALVA DUDE
1974 Bronco Ranger
i ordered a bronco with rock rails, well the badlands comes with them is a better way of putting it. I kinda like the looks of the step rail but think the unfinished area where the rock rails attached looks sloppy/horrible. Plus the step bar instead of rock rails was not an option. I’m wondering if anyone knows if I can put both the rock rails and step rails on at the same time? After seeing so many complaints about rock chips I think the step would help eliminate or significantly reduce chip issues. I realize I can take either off/on and obviously would remove step when off roading. Thoughts?
Way outdated as I am just seeing this. I think I am going with these. I feeling that I may have to mod a bit (weld) but nonetheless, itll look clean and provide that protection that you are looking for. Just food for thought and simplicity.
https://www.pandamotorworks.com/collections/exterior-accessories/products/go-rhino
Baconator
Mansfield, Ohio
2011 Chevrolet Suburban
This fits perfectly along the pinch weld and only takes a couple rolls each side.
Can you post a picture how it (the XPEL) looks installed? Thanks!
Bt_ostate
Oklahoma/Colorado
I didbt take a pic of that. But it looked like spray in liner over pinch welds.and they are covered by the boards but provides added protection
Mike5681
Ohio
More Door Sasquatch
I ordered these for our bronco, wanted the sliders to be able to bolt and weld to the frame and also give a step for all the short people and the women to allow them to get into the bronco easier. SRQ Fabrication
I'm interested in these it wondering if you need to drill holes in the frame or if they use existing holes for the bolt mount, do you know?
DarienJim
James
Jupiter FL
Lots
Gpscharron
Claude
Waynesville, NC
2021 FORD Bronco, RV- Ford E450 (Thor Vegas 24.1)
I think I might be late to the party.. but I love mine. Work great on my Badlands !!
Ford Bronco Step bar with rock rails CA0A631D-9C4D-48E3-BA71-6E60FBB446BE
Ford Bronco Step bar with rock rails 46677F5E-8432-4D84-BF64-7C7627229F79
IAG Support
Wesminster, MD
Has anyone added these from IAG? My preference is more of a full step but I guess these could work. Seems expensive though for what they are do you agree?
https://www.iagperformance.com/iag-v2-ez-step-add-on-2021-ford-bronco-2-door-4-door/
I should have added I like the fact I’m not drilling into anything.
We do offer a full-length step option as well. Please let me know if you have any further questions.
https://www.iagperformance.com/iag-full-length-ez-step-add-on-for-2021-ford-bronco-1-pair/
Baconator
Mansfield, Ohio
For the EZ-Step Add-on…what is the difference between V1 and V2? Is it only the location/height of the step (V1 at top of rock rail and V2 at bottom of rock rail about 2 inches lower)?
Edit (more questions):
What is the weight limit on the V1, V2, and the Full Length for the 2 door?
What is the weight of the Full Length for the 2 door?
Feel free to include the specs on the 4 door also in your response.
Baconator
Mansfield, Ohio
@IAG Support are you guys on a month’s long vacation or what???
