Source material makes a difference with base audio
Garemlin
Delaware
Yes the base audio is not that good. But much depends on what your source material is. I did a little comparison today. I listened to the same song switched back and forth between Spotify and Apple Music set to lossless. Night and day. You get much clear and louder audio at a lower volume. Vocals come out a little better and it doesn't sound as muffled. Still doesn't do much for the highs or extreme low frequencies. But it is a much more pleasant listening experience. The problem is with Spotify and Sirius it is so compressed it just sounds bad. If you have a chance give it a try. Yes it's not drastic. But it makes a difference. I plan to eventually upgrade the speakers, add a sub and small amp. Should sound even better with the lossless audio.
