Running board recommendations, please!
Mitch65
Mitch
Huntongton Beach, CA
2022 Bronco Badlands
Hi All,
What do you recommend for non-powered, easy-to-mount running boards for a 2022 Badlands 4 door Bronco, without having to remove the rock sliders?
Thanks for your wisdom, Mitch
Link1016
Ridgecrest, California
2022 Ford Bronco Badland & 2017 Ford F250
Best option I found that works with the factory rock sliders are the IAG Full Length EZ-Steps.
Ford Bronco Running board recommendations, please! Harry Steps
They are easy to install, are quite solid, and seem pretty durable. They also come off easily if you don't want to scratch them rock crawling - clips on the slider and only uses 2 set bolts per side to fasten. They are also wider in the rear so you can stand on them if you need to access your roof rack. I don't consider it a downside since I like having the ground clearance, but they are flush with the bottom of the rock sliders so they can be quite a step for shorter folks.
As an added bonus, they also do a decent job of deflecting a lot of the rocks that get thrown up by the stock Goodyear tires.
