Rigid Industries Lighting Kits | Overview and Install | Lethal Performance
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Hey All!
We just overviewed and installed the Rigid Industries Roof Line SR Series Light Bar kit as well as their side 360 A-Pillar kit on our First Edition Bronco and thankfully, with the engineering excellence of both Rigid and Ford, the install was super easy and requires no permanent modifications to the truck itself.
Check out the full YouTube Video below!
Ford Bronco Rigid Industries Lighting Kits  |  Overview and Install  |  Lethal Performance rigid-lights-3-jpg
Each kit is supplied with custom-designed brackets made perfectly to fit on the Bronco's OEM Accessory Mounts. This obviously makes the install so much easier, as you don't have worry about drilling into your truck, taking all the thinking out of the install. Simple bolt-on assembly!
Ford Bronco Rigid Industries Lighting Kits  |  Overview and Install  |  Lethal Performance rigid-lights-2-jpg
All of the hardware and brackets in these kits are Stainless Steel construction, making them rust-resistant and durable for any climate.
The Light Bar, Pods, and A-Pillar Brackets are given a UV and Scratch-Resistant powder coating finish to make them even MORE resilient to whatever you throw at them.
Ford Bronco Rigid Industries Lighting Kits  |  Overview and Install  |  Lethal Performance bronco-access-rigid-png
Of course, Rigid always goes above and beyond with these kits, supplying full, pre-measured harnesses, lens covers for when not in use, as well as tinted lens covers, along with bracket covers to better hide the brackets at the top of the truck and make it more aesthetically pleasing.
Check the A-Pillar Kit here below!
https://www.lethalperformance.com/rigid-industries-2021-ford-bronco-a-pillar-light-kit-incl-360-spot-and-360-drive-46722.html
Check out the Roof Line Light Bar Kit Here!
https://www.lethalperformance.com/r...t-kit-incl-sr-spot-flood-combo-bar-46724.html
They also sell the brackets separately if you'd like to mount your own accessories in their place.
Have questions or want to get something on order? Feel free to reach out to me or any one of us on here, shoot us a call at 561-753-8105, or shoot us an email at support@lethalperformance .
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
Ford Bronco Rigid Industries Lighting Kits  |  Overview and Install  |  Lethal Performance 1637347377084-png-png-png
