RESZ Fab Frame Mount Rock Sliders (2dr only)
j_marinelli
Spring Branch, TX.
Stumbled on these today and thought I would share.
https://reszfab.com/product/new-bronco-frame-mounted-rock-sliders-bolt-on-2021/
Ford Bronco RESZ Fab Frame Mount Rock Sliders (2dr only) 20200225_160627-01-scaled-e1582668179472
Ford Bronco RESZ Fab Frame Mount Rock Sliders (2dr only) 20211117_165356-01-scaled-e1643232000972
Ford Bronco RESZ Fab Frame Mount Rock Sliders (2dr only) 20211117_165046-01-scaled-e1643232108413
Ford Bronco RESZ Fab Frame Mount Rock Sliders (2dr only) 20211117_165425-01-scaled-e1643231967756
From their site:
Protect your new Ford Bronco with our frame mounted heavy duty rock sliders. These are built in-house at RESZ Fabrication located in Northeast Ohio, using American made steel. Our rock rails are built from 1.75″ x .120″ DOM tube, 3″ x 2″ x .120″ rectangular tube, and 2″ x 2″ x .188″ square tube. The frame plates are CNC cut from 1/4″ thick hot rolled pickled & oiled steel.
Since there are next to no threaded holes in the frame, we use a combination of holes that run through the frame, OEM threaded holes, and rivet nuts (“Rivnuts”). While these aren’t 100% bolt-on, they do require some drilling into the frame (see warranty note below). The passenger side will require the most holes to be drilled as the gas tank sits just inside the frame making it very difficult to utilize existing holes in the frame. We will provide all the necessary hardware (3/8″ & 1/2″ grade 8 bolts) including the rivnuts (3/8″) and rivnut tool to get these mounted to your Bronco.
*Warranty Note – Before making these we contacted both our local Ford dealership and Ford corporate headquarters to make sure the new holes that needed to be drilled wouldn’t void the factory Warranty. Both replied with “no, that will not void the factory warranty.”
Current Lead Time: 16-20 weeks
luvmybronco
Loudon, TN
1968 Bronco sport, 1969 Bronco sport, 1990 F250 Lariat 4x4, 2015 F150 Lariat super crew 4x4
Lolife
Tom
Mi
2015 F150
Would love to get my hands on a 4dr version of that once my ship comes in…. Ugh
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
Jr87mustang
Josh
Northern Cali
Finally a thread that 4 door owners can complain in!
But when are you going to make them for the 4 door version?!?!?! lol
skiborsy
SF Bay Area
TRX, Badsquatch
Given the 2 door version has 16-20 week lead time, even if there was a 4 door version now you might be waiting 5 months!
