Rear Facing Roof Rack Mounted Lights
audipwr1
Matt
Cali
ford and others
Anyone see a kit for this?
Want to mount two lights up on the roof rack facing backwards for lighting while working / camping from the back of the bronco
Also I dont see a super easy way to pass a wire from the cabin up there, is there a premade hole somewhere to feed a wire up to the roof cross bars?
Kameronatm
Kameron
Bronco Badlands 4dr
I am trying to figure out the same problem, but I want to mount a pair of SSC2 lights towards the sides. I am thinking you either come up through the a pillar and run the cable along the side roof bar, or you wedge it between the 2 rear roof panels. this seems to be what Ford did in their overland build. If you look closely at the interior shots you will see loose wire above the roll bar and under the rear roof section. I am also wanting to make sure that I have QD points near the body so that I can remove the top and not have 4-6 ft of dangling cables.
audipwr1
Matt
Cali
ford and others
yeah would be mounting them to my yakima small roof platform - wide and at the back, was thinking pickup the aux wiring from the back pickup point, but getting it from there to the roof doesnt appear to have an OEM like solution. Not a fan of pushing it through a gasket or drilling a hole in the roof at all
Kameronatm
Kameron
Bronco Badlands 4dr
min 2:58 may be a simple solution
