Raptor take offs on a BB?
Trivisual
West michigan
2dr 22 big bend
I have a non-sas BB 2 dr, found some raptor take-offs, 37's. Beyond a lift, crash bar removal, ecm setting change, would these bolt right up? problems with TPMS? obvious alignment as well. thanks!
kodiakisland
Arkansas
Different size bolt pattern, unless you are talking about Ranger wheels.
They do make adapters.
Trivisual
Trivisual
West michigan
2dr 22 big bend
No, bronco raptor wheels. They are 6x135 wheels...just wondering if offset is a crazy positive or negative value that folks know wont fit..
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
To answer the most important question first: the Bronco Raptor wheels won't bolt right up to a non-Raptor Bronco.
We have a non-Sas BB 2 DR and a Raptor. BB wheel bolt pattern is 6x139.7; Raptor Bronco bolt pattern is 6x135. Also, studs on Raptor are a different size thread, but I've never compared the two wheels to see if the hole size is different.
Not saying it's impossible to get them to fit, but it's not as simple as bolting them right up without additional parts and modifications.
Haelous
US
2016 Mustang GT, 2023 Bronco Wildtrak
Doesn't the Bronco Raptor use the same hubs and wheels as the F-150 Raptor?
Raptor911
Raptor911
Broadlands, VA
NO. Bronco raptor wheels will not work on a base bronco
Both are 6 bolt patterns, should be fine. I would venture into an upgrade axles/suspension. Waiting on Spicer axles and danatek 44s before I upsize mine.
Bronco-saurs
Eugene
2020 Explorer / 2018 F150
This is not accurate.
Stand corrected, I was talking with my buddy and was referencing his build, his isn't remotely close to the stock setup anymore. My bad!
BroncoAZ
Mitch
There is a guy on here somewhere in Massachusetts with a red 2 door base with Gen 3 F-150 Raptor takeoff 35” tires using a wheel adapter. It looked great.
