- Alkesh
- Apr 2, 2022
- 97
- 269
- 291
- South Carolina
- Yukon
- Undecided
All Raptors deserve this exhaust! In stock and ready to ship is the Magnaflow Cat Back system. The MagnaFlow Ford Bronco Raptor Overland Series Cat-Back Performance Exhaust System brings all the technology, dyno-proven performance and configurable sound your truck needs to be crowned the ultimate Raptor. This exhaust kit is compatible with every 2022-2023 Ford Bronco Raptor running a 3.0L engine and features an easy-to-install direct-fit design that replaces your truck's OEM exhaust system from near the catalytic converter on back. #19619 features high clearance tucked 3" diameter mandrel bent main piping that passes through two 11" round body straight-through mufflers and NDT (No Drone Technology) resonators, effectively mitigating any droning noises that may otherwise occur when cruising at highway speeds. The tucked design also considerably improves both ground clearance and departure angles. This Ford Bronco Raptor performance exhaust system terminates in a dual same-side driver-side rear exit and includes integrated, functional active exhaust valves cast in durable 304 stainless steel. Exhaust kit #19619 is secured using racing-bred quick-release V-band clamps. #19619 is made of durable stainless steel and produced using advanced 3D scanning technology and CNC precision robotic manufacturing techniques, all backed by MagnaFlow's limited lifetime warranty.
