Pulling a wire into the Engine Bay fuse panel for T-tap install
manolan478
Milton
Elberton, GA
2022 Wildtrak 2.7L Sas Cyber Orange
Has anyone pulled a t-tap fuse cable into the engine fuse panel? I am adding some grill lights and the vendor suggest using the t-taps. But, the fuse panel is pretty sealed up. Has anyone driller a hole or installed a rubber membrane like the one going to the inside fuse panel?
I just don't want water or debris getting into the engine block and short out the block or become an issue down the road.
I was hope there was a way to pull the cable up into the fuse block from below...
Any suggestions?
Lak34ers
Troy
Seattle
Any suggestions?
You can just t tap into the parking light wire above the wheel well. I did this for my Diode Dynamic backlighting so it come right on when bronco is started. Diode Dynamic had a video on how and where to t tap for the elite bronco fog lights.
Lak34ers
Troy
Seattle
Any suggestions?
Found it. Last part of the video.
https://www.diodedynamics.com/elite-series-fog-lamps-for-2021-2023-ford-bronco-pair.html
manolan478
Milton
Elberton, GA
I appreciate the video and response. but. I was actually looking for something different. There are fuse taps that allow two fuses to use a single slot. Two light additions were suggesting I use a specific Fuse tap to utilize one of the accessory fuses. But, I could not figure how they wanted me to run the actual wire with the fuse tap into the engine bay fuse box without putting a hole in the plastic cover of the fuse box. Not ideal.
I like the T-Taps and have used them many times in an RV. But, I was really trying to penetrate the engine bay fuse box and wondered what other folks did.
Should I remove the screws in the fuse bay and lift the assembly out and pull my cable up through? I have never done that and don't want to damage my fuse box.
shurdba
Encinitas, CA
2022 Bronco 2 Door
manolan: Did you ever try pulling the fuse box assembly out to route a wire from the bottom? I'm looking to put a kill on the fuel pump. Thanks
I did a hole in the lid with a rubber grommet, and then heatshrinked the wire going through so it was a tight fit. It's not submergable-tight, but it's spray-tight.
Dbrun2000
Dbrun
2024 Bronco Wildtrak
Any suggestions?
IAG makes a cover to replace the stock one that has 8 wire slots to run into fuses
