- Jul 18, 2023
- 256
- 614
- 582
- New York
- Website
- www.broaddict.com
- Bronco Badlands
- Badlands
Are you a proud owner of the Ford Bronco 2021-2024? If so, the Broaddict Front Door Hanger Bracket might just be the perfect accessory for you. Designed specifically for both 2-door and 4-door models (excluding the Sport version), this heavy-duty steel bracket ensures your Bronco doors stay protected and conveniently stored.
Compatibility and Protection The Broaddict Front Door Hanger Bracket is tailored to fit Ford Bronco models from 2021 to 2024, ensuring a snug and secure fit. By utilizing this bracket, you can hang your doors safely on the wall, shielding them from potential scratches and damage. This not only preserves the pristine condition of your Bronco doors but also optimizes storage space, making it an ideal solution for those with limited garage or workshop space.
Premium Build Quality Crafted from robust steel and finished with a durable black powder coating, these brackets are built to last. They boast exceptional strength and resilience, remaining rust-proof, corrosion-resistant, and resistant to bending over time. This ensures your investment in quality protection and storage for your Bronco doors.
Easy Installation Setting up the Broaddict Front Door Hanger Bracket is straightforward. Simply align the pre-drilled screw holes with the wall, secure with the provided bolts suitable for plasterboard or drywall (drilling required), and you're all set. The package includes everything you need for a hassle-free installation, ensuring you can start enjoying the benefits right away.
Conclusion In conclusion, the Broaddict Front Door Hanger Bracket offers a reliable and practical solution for Bronco owners looking to protect and store their doors efficiently. Its sturdy construction, easy installation process, and tailored compatibility make it a must-have accessory for any Bronco enthusiast's garage or workshop. If you're seeking a way to safeguard your doors while maximizing space, look no further than this top-notch door hanger bracket.
Click here and Learn more about it: Wall Mount Door Storage Hanger Bracket
