Anybody have pics of 17x8 0 offset wheels on 34's 10.5 wide tires? Please & thanks.
Thanks for your wisdom. Lots to consider here.Check the tire upgrade thread but of the pictures I've saved from here, I have one listed as a 17x8 with 18 offset but no idea what size tire (my guess is 285/75/17). So a 17x8 with 0 offset would stick out around 3/4" more than this but a 10.5" wide tire would probably be 3/8" narrower on each side. I think this Bronco has the standard non Sasquatch flares.
My wheels are 17x9 with -6 offset running 35x12.5x17 tires. I have a base Sasquatch so it has the wider flares and they stick out probably 1-1/4" more than stock.Thanks for your wisdom. Lots to consider here.
I love your set up also. Same steels I'm looking for. If you don't mind can I get your wheel and tire specs and how much it pokes out.
Please and thanks
Check out this site. It's a before and after wheel offset calculator. Enter what you have currently and what size tire and wheel offset you want to change to and it will calculate the measurement difference.Thanks. Looks awesome. Unfortunately I have the standard flares so they'll stick out like a sore thumb.
I'm still unsure on how much it'll poke out with the 17x8 0 offset wheels on 34's 10.5 wide tire set up. I'm a newbie to this game lol
ThanksCheck out this site. It's a before and after wheel offset calculator. Enter what you have currently and what size tire and wheel offset you want to change to and it will
https://tiresize.com/wheel-offset-calculator/
That doesn't stick out that much. I think I could live with that. Thanks35x10.5 on 0 offset with standard flares. I didn't take any pics to specifically show poke but it shows up in the background of this pic.
Looks great! I have the same wheels with a 295/70r17 on a non sas. I like how they poke out. Oh and a little tip.. I took the cap off my spare like you did for the camera but I got a hole saw and cut out the center. It fits nice and tight and looks a lot better. Dont have a pic of it tho.My wheels are 17x9 with -6 offset running 35x12.5x17 tires. I have a base Sasquatch so it has the wider flares and they stick out probably 1-1/4" more than stock.
I actually bought a no name center cap that was taller off Ebay and cut out the center for the camera.Looks great! I have the same wheels with a 295/70r17 on a non sas. I like how they poke out. Oh and a little tip.. I took the cap off my spare like you did for the camera but I got a hole saw and cut out the center. It fits nice and tight and looks a lot better. Dont have a pic of it tho.
Looks good. Never woulda thought about that.I actually bought a no name center cap that was taller off Ebay and cut out the center for the camera.
