Payload = 895 lbs (2025 4Runner Trailhunter)
Gastan
Active member
Cali
Tacoma TRD Pro
Per the TFL Truck video, here's the door sticker label showing payload of 895 lbs on the 2025 Trailhunter 4Runner
2025 Toyota 4runner Payload = 895 lbs (2025 4Runner Trailhunter) Payload = 895 lbs (2025 4Runner Trailhunter)
From video
Aonarch
New member
North GA / MT
ā€˜23 Bronco OBX 2DR Lux 2.7, ā€˜16 Corvette Z51
Pathetically low.
After two adults that is around 555 pounds.
Plus if you tow anything you have to take into account the tongue weight eating into pay load.
SnowRunner
New member
Canada
Murano
Keep in mind this is still an early prototype, the final numbers may be different. Also, the TH comes pretty loaded, some people may not need much 3rd party mods after.
RedHawk
New member
ATL
2017 Chevy Colorado ZR2
Trailhunter with 895 lbs payload - how would you have people, stuff, and tow a small camper (like 410 hitch weight + people + stuff > 895).
blacksapphirez
New member
CHS
2023 Bronco Badlands
wrangler 4dr is about the same. with new suspension/tires, i'm sure it can be higher
Bronconomore
Well-known member
Canada
Bronco Sport
I am somewhat perplexed on this one. If the new Landcruiser is using the same exact frame, axles, suspension, and powertrain as the 2025 4Runner and Tacoma, why then is its payload so much higher at 1600 lbs?
Gastan
Gastan
Active member
Cali
Tacoma TRD Pro
This thread posted over the weekend at Tacoma4g shows that the door sticker payload figures should be ignored.
https://www.tacoma4g.com/forum/thre...els-curb-weights-gvwr-payload-published.4194/
The final official payload figures published by Toyota are higher for the 2024 Tacoma than listed on their door stickers. Seems like they just picked a random number for the door sticker for whatever reason.
Bronconomore
Well-known member
Canada
Bronco Sport
Those numbers seem more in line with the LS. Hopefully the 4Runner will also be updated to reflect the same.
pisces22
New member
NC, USA
2016 Honda Accord
My 2016 Accord has a payload of 850 pounds so I'm guessing these figures aren't accurate.
Bronconomore
Well-known member
Canada
Bronco Sport
Payload on the 2024 LS 1958 edition is 1100lbs not confirmed. Assuming the higher trims will get less payload.
So maybe the 4Runner Trailhunter we have seen on YouTube is not incorrect at 895lbs.
Boobajoob
Calgary, AB, Canada
Escape
Iā€™m confused, isnā€™t the payload just GVWR minus curb weight?
On Toyota.com the iForce Max LCā€™s show 6725 and 5037.5 lbs. Would that not put its payload at 1688lbs? Why would it be limited to 1100lbs?
