No manual on Badlands 4 door?
Ogriofa
Jared
Nothing
I was checking the engine specs between the badlands 2 door vs 4 door when I noticed the 4 door did not seem to have a 7 speed manual option. The 2 door specs are to the left and 4 door to the right. Anyone happen to know if the badlands specs online are off or if the 4 door really only comes in automatic?
Ford Bronco No manual on Badlands 4 door? 9EE98388-F446-4A3C-8FE3-4C1D9A96BBB1
Toccoa
Isuzu Rodeo Sport
Looks like it‘s an option to me. 2.7 is auto only.
Ford Bronco No manual on Badlands 4 door? 1595653534802
Ogriofa
Jared
Nothing
This also conflicts with the tow stats on the same page which suggest 4 door manual...
Ford Bronco No manual on Badlands 4 door? D7EA7613-81E5-4D9B-B811-4F3EAA49C80A
Ogriofa
Jared
Nothing
Ya I saw that too. I was just mainly confused by the above specs as it doesn’t match any of the other stuff on the website. Thanks for the reply btw.
Toccoa
Isuzu Rodeo Sport
You’re reading this wrong. The left column is for the 2.3L and the right is for the 2.7L. Number of doors does not effect the engine (except for speed and weight).
kodiakisland
Arkansas
Yeah, don't see anything about 2dr or 4dr, just the two engine specs.
DrewBronc21
New York
2020 Subaru STi, 2024 M2
I noticed the same thing. the format on the website is left column 2DR and Right column 4 Dr. under highlights it appears both transmission options for 2 and 4 door:
but further down the left column 2DR and right column 4Dr would suggest that the 4 door only available with 2.7.
Ford Bronco No manual on Badlands 4 door? 1081DDBF-F27A-4D28-A506-F20F8BCC39EB
Ford Bronco No manual on Badlands 4 door? FBE8BF8D-8345-42E1-A7FD-49B3122759F4
BabyDoc1012
New Bern, NC
2020 Sierra, 2019 Ascent
The spec sheet is only showing the difference between the 2.3 and the 2.7. It is kind of confusing though. The only model that I can see that is automatic only for the 4 door is the base model, which is kind of weird. Honestly at this point we are so anxious for information we have all poured over this information probably a 1,000 times. I think the best thing is wait until the configurator comes out.
Lonestar777
That's just poor/confusing website design. As you said, in the top sections they set the expectation that left column is 2 door and right column is 4 door. In the lower sections they switch that around so left column is 2.3L and right column is 2.7L. It confused me when I first saw it as well.
