Sold: Virginia Military Light Tactical Trailer Adventure Camper & Toy Hauler
71Br0nc
M1101 Military Light Tactical Trailer - Rugged Adventure Camper & Toy Hauler + Off-grid gear
Built on the Military Light Tactical Trailer framework (m1101, M1102), rugged, rough, 30" ground clearance, and capable of hauling 2400 lbs makes this the ultimate bugout camper trailer. This trailer is light enough for the Bronco to tow, roughly 1800 lbs total with trailer, top, and gear. Even a Subaru Outback or small SUV can tow this. Short enough to reduce drag on the road. Secure enough to keep your gear locked up and safe inside this mini fortress. It's tough enough to take a beating. Lifetime tough Line-X inside and out with a solid aluminum top (Gun Metal Grey Powder Coated) that can support 1000+ lbs on top. You won't be disappointed.
Located in the DMV (DC, Maryland, Virginia). Stored in Virginia, right on the West Virginia border. $10,990
Trailer is ready to go. The trailer, solar battery system, tent, and awning are new and installed. Other accessories are included but not installed. Bill of Sale, but no title. This is minimalist to keep costs low and allow the DIY guy to built it out. The tops alone sell for $6000 - it's a steal.
What comes with the overland camper trailer?
  • Military M1101/M1102 Tactical Trailer (new, old stock)
  • Standard 37″ HMMWV Tires (nearly new)
  • Custom Aluminum Top, Powder Coated (locking rear door, roof holds 1000+ lbs)
  • 7-PIN Wiring Harness & 12-PIN wiring hardness
  • LED Trailer Exterior Lights (upgraded from incandescent)
  • LED Trailer Interior Light (super bright)
  • LED License Plate bracket (mounted, LED not wired)
  • Rear 2″ Hitch (for all those accessories)
  • CU Off-Road Max Coupler Articulating Hitch & Mount (included, not installed, simple bolt-on)
  • Line-X Coating (inside & outside of trailer, but not underneath)
  • Pintle Hook & 12″ raised, 2″ military hitch included (ready to be towed away)
  • HiTent Awning (new)
  • HITent Rincon 3 Person Roof Top Tent (60 second pop-up) 56″wide X 132″long X 50″ tall (some external cover straps have frayed from sitting in the sun, new ones included)
  • 12V SAE Solar Connector
  • NOCO AC Port 120V Shore Power Connector
  • 120V Battery Charger & Maintainer (shore power)
  • 30 Amp Solar Charge controller
  • 35ah 12V Battery Backup System (all connected & working)
  • (2) 20-30# Propane Tank Mounts (Cover included, but not installed on trailer tongue (no tanks included)
Other Gear Included, but not installed
  • (2) Hardigg Military Wheeled Chest Waterproof, Crushproof (31"x21"x15", excellent to new condition)
  • Accessory T-Slot Rails (new, not installed)
  • (2) LED Spot/Flood Lights w/SAE connection (new, not installed)
  • 85 Watt Solar Panel (new, not installed)
  • Viair Light Duty On-board Air (OBA) System (new, not installed)
  • (1) 9 Gallon (1) 12 Gallon Water Tanks (non-pressurized, new not installed)
  • Pop-a-bowl, pop-a-napkin, pop-a-towel, pop-a-plate (new)
