Mabett Aluminum Alloy Cargo Trunk Hooks Available Now
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
Buy "Aluminum Alloy Cargo Trunk Hooks" through this link and get 30% off promotional offer: https://www.amazon.com/gp/mpc/A19OCZ7N2CPBPL
  • Note: Please return to this page to redeem the discount after the promotion starts on 2022-8-13 05:00 PDT
  • Note: Please operate when “Aluminum Alloy Cargo Trunk Hooks” is available
PRODUCT DESCRIPTION
  • Organize all the stuffs such as groceries, umbrella or anything that are easy to broke or will roll. This is a must have trunk hook for every Ford Bronco owner.
  • Fit all full-size two-door and four-door Broncos that have speakers mounted to the rear roll bar. Just remove the lower speaker mounting bolt, install the Hook and screw the bolt back in.
Cfield90
South FL
21 Bronco/22 Escape/01 Softail/90 Bronco (former)
I had bought some 3-D printed ones before I even had the Bronco and after install was concerned about them holding up; that's no longer a problem with Mabett's. These allow for for not only additional weight but also width. These are solid!
Ford Bronco Mabett Aluminum Alloy Cargo Trunk Hooks Available Now 20220818_174113
Kimberley
Vermont
@Mabett these are solid and look great but they do come a little too close to the roll bar where I could see it scraping. Looks like @Cfield90 used a plastic washer between and I myself used some of the left over padding from your mudflap install.
Ford Bronco Mabett Aluminum Alloy Cargo Trunk Hooks Available Now 1661701497794
Ground_zero298
Scs michigan
Original kit came with the square back spacers.
Headsong
Love these, but not the price... For a couple of hooks ..
Kimberley
Vermont
Double checked all the packaging and mine did not come with any spacers. Also no mention in the instructions I received.
Ground_zero298
Scs michigan
Nice thing about the black with the polished edge is it can be color matched to the truck with candy paint.
Cfield90
South FL
The original 3D printed ones had the spacers; I used the ones from the 3D kit, and most definitely had the same concern you did. @Mabett these plastic spacers would be a good addition the your hook kit. @Kimberley you have a very keen eye 😉
Mabett
Mabett
Mabett
China
www.facebook.com
Thanks for the reminder, I did overlook this
Ground_zero298
Scs michigan
Ordered. Will post up the color match when I get them.
Erock
US
2018 F150 Alpine edition
Ever thought about running a radius cutter around them instead of the chamfer cutter? They’d be much more appealing in my opinion.
Mabett
Mabett
Mabett
China
www.facebook.com
Good Ideal, i will consider
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Mabett, are you including spacers now or cutting them slighter shorter to avoid the scraping? Also, on Amazon they come in a 4-pack (black), 4-pack (silver), and a 2-pack (silver). Why no 2-pack in black? I have a few of your different products already, and would love to add these hooks, but would like these couple issues addressed first. Thank you.
Mabett
Mabett
Mabett
China
www.facebook.com
Sorry, I didn't give away spacers
I will ship it in mid-October
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
@Mabett do these cargo hooks work with your new rear 6.5" speaker pods? Just wondering if the larger size pods now affects how these hooks install. Thank you.
