m 2 m___d e v i c e___r a i l || NO DRILLING
What do you fancy gadget do you desperately need to mount to your dash?
  • Total voters
Cody@Mountains2Metal
Cody
Wilson, N.C.
2021 Ford Bronco 2D Manual
Our Dash Mounts are made for the noble Bronco-owners that keep drill bits away from their precious โ€˜investmentโ€™. They come in two sizes, so whether you are planning on keeping it simple or adding every device you can think of we have an option for you.
๐Ÿ‡บ๐Ÿ‡ธ๐Ÿ‡บ๐Ÿ‡ธ๐Ÿ‡บ๐Ÿ‡ธ๐Ÿ‡บ๐Ÿ‡ธ๐Ÿ‡บ๐Ÿ‡ธ๐Ÿ‡บ๐Ÿ‡ธ๐Ÿ‡บ๐Ÿ‡ธ๐Ÿ‡บ๐Ÿ‡ธ
  • American made steel and laser cut in house, then powder coated black​
  • Uses the existing 1/4-20 bolt location on your dashboard and hook into the defrost A/C vents​
  • The slot pattern on them utilizes dimensions capable of mounting any 2-Hole or 4-Hole AMPS pattern bases​
  • MADE IN THE US OF A​
We do not currently sell attachments nor will the dash mounts come with attachments at the moment. There are 1/4-20 Pem-Nut locations for various 1/4-20 bases (3 on the Small and 5 on the Large).
If you have one already post a picture of your setup below!
Ford Bronco m 2 m___d e v i c e___r a i l  ||  NO DRILLING dsc07319_1__99600.1682537791
Ford Bronco m 2 m___d e v i c e___r a i l  ||  NO DRILLING dsc07323_1__40932.1682537794
Ford Bronco m 2 m___d e v i c e___r a i l  ||  NO DRILLING dsc07483__27819.1682537798
Ford Bronco m 2 m___d e v i c e___r a i l  ||  NO DRILLING dsc07334__34925.1682537802
Ford Bronco m 2 m___d e v i c e___r a i l  ||  NO DRILLING image_20230426_144131_955__09042.1682537805
Ford Bronco m 2 m___d e v i c e___r a i l  ||  NO DRILLING dsc07337__49080.1682537808
ET13
Honda
Can you tell me where those attachments youre using came from?
ET13
Honda
Not only no screws, but also no double-sided tape. I run phone, go-pro and cb mic holder on mine, works great so far! Solid as a rock.
How do you have the phone charger getting power?
ET13
Honda
Getting ready to purchase. Any coupons currently?
