- Sarah
- Sep 19, 2022
- 18
- 177
- 326
- CA
- Website
- www.boss4x4.com
- '22 Sasquatch 2DR; '78 FJ40; '85 T4R
- Base
CLICK ON NAMES FOR MORE INFO or this LINK.
First 5 Orders will receive a FREE 0-60 PSI Tire Gauge ($18 value)! Mention Bronco6G Forum in order comments.
Mean Mother:
Exitrax branded: $116.99 (10+ available) ***BEST VALUE***
The Exitrax Heavy Duty 12V Air Compressor has been designed for serious off road use. Although a "budget conscious" compressor, it is packed with plenty of inflation power, it delivers an incredible 160 litres per minute free air delivery (9,700 cu in/min).
Mean Mother AIR COMPRESSOR 110PSI / 6,700 CU IN/MIN: $139.00 (10+ available)
The Mean Mother MMACM3 Maxi 4X4 3 Heavy Duty 12V Air Compressor has been designed for serious off-road use. Packed with plenty of inflation power, it delivers an incredible 110 Litres per minute free air delivery.
Mean Mother AIR COMPRESSOR 150PSI / 8,800 CU IN/MIN: $179.00 (10+ Available) ***OUR CHOICE for Single Compressor***
The Mean Mother Adventurer 4 Heavy-Duty 12V Air Compressor has been designed for serious off road use. Packed with plenty of inflation power, it delivers an incredible 180 Litres per minute free air delivery.
TJM:
TJM On Board Air Heavy Duty Compressor w/ Wire Harness: $299 w/FREE Shipping (10+ Available) ***TOP Seller***
TJM Pro Series Single Air Compressor delivers an imposing 86 litres-per-minute for speedy inflation, which is made possible thanks to its powerful internal componentry and advanced cooling system.
TJM Pro Series On Board Air Twin Compressor w/ Wire Harness, 12V: $559.00 w/FREE Shipping (10+ Available)
TJM Pro Series Twin Air Compressor delivers a blazing 170 liters-per-minute for lightning-fast inflation, which is made possible thanks to its powerful internal componentry and advanced convection cooling system.
ARB:
So what makes these compressors special? They're small enough to fit into even the tightest space and quiet enough to mount in the cab. They have enough output to air up four 35 in. to 37 in. tires in a single duty cycle and typically air up a 35 in. tire in just over two minutes.
ARB On-Board Air Single Compressor, 12V: $241.00 (10+ Available)
ARB High Performance On-Board Air Compressor, 12V : $338.00 (10+ Available) ***Great for Air Lockers***
ARB Twin Air Compressor, 12V: $616.00 (10+ Available) ***BEST Seller***
OVS:
EGOI Permanent On Board Dual Motor Air Compressor System 6.1 CFM: $449.99 (10+ Available) ***NEW***
The UDA EGOI 2 Air Compressor is full of power and designed to withstand the most extreme elements.
VIAIR:
VIAIR 450P Automatic Portable Air Compressors 45043: $314.95 (7 Available)
VIAIR 450P automatic portable air compressors offer an automatic shut-off function in a larger portable compressor.
VIAIR 450P-RV Automatic Portable Air Compressors 45053: $350.95 (7 Available)
VIAIR 450P-RV automatic portable air compressors offer an automatic shut-off function in a larger, powerful portable tire inflator.
VIAIR 400P Portable Air Compressors 40043 : $215.95 (6 Available)
VIAIR 400P Series air compressors feature an oil-less design, a high performance PTFE piston gear, and a gearless direct-drive motor.
VIAIR 400P Portable Air Compressors 40045: $299.95 (2 Available)
VIAIR 88P Portable Air Compressors 00088: $89.95 (10+ Available)
Compact, yet capable of inflating up to 33 in. tires.
VIAIR 300P Portable Air Compressor 30033: $178.95 (10+ Available)
These portable compressors feature a 33 percent duty cycle at 100 psi, providing 2.4 cfm, and are rated for use on vehicles with the oversized tires.
VIAIR 275C Series Air Compressors 27520: $231.23 (8 Available)
VIAIR 275C series air compressors feature an oil-less design, high-performance PTFE piston gear, and a gearless direct-drive motor.
Mean Mother:
TJM:
ARB:
OVS:
VIAIR:
