- Caleb
- May 3, 2022
- 233
- 1,007
- 843
- St Louis MO
- 2021 Bronco
- Outer Banks
If you've been looking for an easy install mount for your ARB Single or Twin Compressor, look no further. KR Off-Road were the first in the industry to offer a commercially available ARB mount for the 2021+ Bronco. This system is 100% bolt-on and uses factory mounting points. With support for both the 2.3L and 2.7L engines you'll be able to mount the ARB Single Compressor or the ARB Twin Compressor under the hood of your vehicle.
KR Off-Road ARB Compressor Engine Bay Mount
FEATURES
ARB HIGH OUTPUT ON-BOARD 12V AIR COMPRESSOR
The most popular in our range, the ARB High Output Air Compressor has been constructed entirely of lightweight, high-grade materials and is available in both portable and vehicle mounted configurations. With a class-leading flow rate, this compressor has been designed for Air Locker® activation (on-board model), fast tire inflation and a range of other functions whether they be for work or play.
ADDITIONAL FEATURES
ARB MAXIMUM OUTPUT 12V ON-BOARD COMPRESSOR
Providing optimum power, the ARB twin motor design delivers class-leading air flow for fast inflation purposes. Constructed of lightweight, high-strength engineering grade materials, it incorporates quality components for quiet operation and extended durability. The twin motors incorporate internal thermal protection against extreme temperature damage while a heavy duty in-line maxi fuse for each motor provides professional circuit protection.
ADDITIONAL FEATURES
Check out our YouTube video going over the KR Off-Road mount for the ARB Compressor here! At this time we do have these kits in stock, ready to go. If you have any questions on these products or are interested in purchasing, please feel free to send me message! Also, don't forget to use code: "Bronco6G" at checkout for a discount!
FEATURES
- .135" (10 Gauge) #304 Stainless Steel
- Powder Coated Black Finish
- Designed & Manufactured in the USA
- 1 Bracket w/ Support Bar
- 2021+ Ford Bronco 2.3L
- 2021+ Ford Bronco 2.7L
ADDITIONAL FEATURES
- Sealed for moisture and dust resistance
- Hard-anodized cylinder bore for reduced friction
- Teflon-impregnated carbon fiber piston seal for maximum trouble-free life
- Anodized mounting bracket dissipates motor heat and allows compressor to be repositioned 180 degrees on vehicle mounted models
- Quality components for quiet operation and extra long life
- Constructed entirely of lightweight, high strength engineering grade materials
- Over-pressure safety valve equipped
- Motor is internally thermal protected against extreme temperature damage
- Heavy duty maxi-fuse equipped for professional in-line circuit protection
- Designed for inflating Tires and air locker activation when used in conjunction with optional accessories
- Suitable for many air tools when used in conjunction with a 4L air tank (optional with on-board models)
- 100% duty cycle
- Hard anodized cylinder bores for reduced friction
- Teflon impregnated carbon fiber piston seals for maximum trouble free life
- anodized mounting bracket dissipates heat
- Integrated pressure switch, relays and IP55 (waterproof/dustproof) brushless fan cools electronics, motors and cylinder heads
