Kicker key tuning help
PghBronco
Matt
Pittsburgh
Picked up a kicker key 200.4 works perfectly. However, I cannot get the tune right.. It sounds really flat.
Prior to key audio mods:
Dash: Kicker 47KSC404 (150mhz blockers)
6.5 kick panel (Focal rcx-165)
6.5 rear (Focal rcx-165)
8-in kicker 46L7T84 sub
JL MX300 - Sub amp
Installed just like the other posts on the key amp. gains set to 0, (read somewhere to unplug the sub so i did that)
Dip switches are set (from memory):
Auto 12v - up
fader: on
compression: off
bi-amp: off
kicker eq: on
time delay: On
*** Last two for amp 1&2 i have it set to 60Mhz
I pulled up a pink noise from spotify to play not a direct download to my phone, that was also played through carplay this could be the issue? the auto tune ran its cycle just fine no bad beeps, im wondering a couple of things..
the eq settings were all set to neutral***
Afterwards it was like a very loud tin can.. no bass at all especially from the kick panels. But there has to be a bass signal considering the sub is working? So i increased amp 1 gain and got my bass back, then increased the bass sensitivity (on sub amp halfway) which fixed it somewhat, however i still hear the tin can. My eq setting for the vehicle are treble all the way down, mid all the way up and bass middle.
Can i reset, and plug the key in and just have it push power to the speakers without the auto tune?
should I run the auto tune again with the bass?
I saw a video of a key installation which after the auto tune the mic button becomes a before and after button so you can see the "improvement" thought this was neat, i did not verify it.
open to any ideas, tia
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Feels like you're just randomly changing things in the dark here.
Before you run the Kicker configuration, you need to...
  • Turn off the subwoofer amplifier
  • Change the tune settings in the Bronco to default
  • Turn off all high-pass filters on the Kicker
  • Turn all gains on the Kicker to the minimum setting
  • Download and use an uncompressed pink noise file, not some random pink noise on Spotify
  • Load the pink noise file onto a USB drive and use that. Or, if you don't have one, make sure all EQ settings are turned off on your phone.
PghBronco
PghBronco
Matt
Pittsburgh
Okay I’ll go though this list in a bit. Do I need to reset the amp to run the tune again?
RagnarKon
Bryan
New England
Yup.
Instructions in the user manual.
WTX Bronco
West Texas
2023 4DR Black Diamond Sasquatch
JL MX300 - Sub amp
Auto 12v - up
fader: on
compression: off
bi-amp: off
kicker eq: on
time delay: On
I installed 6.5 kicker ks in the kick panel and had the same issue with no bass/just didn’t sound good. Swapped them out for 6.5” woofers and it was by far the best upgrade I made to the sound system.
Hertz Cento Series C165 are the ones I went with.
NCLife
Charlotte NC
2019 JLUR
Looking for a little help here as well. I have upgraded all of my speakers to the usual Kickers everyone recommends, fore and aft. I installed the Kicker 200.4 yesterday but couldn't get the auto tune to run. I followed all the instructions. However, when I press the in-line button, I get a single tone with no follow up tones or action. If I press it again I get two tones and nothing. I tried it a dozen times or more. Any ideas?
