Arizona JBL Basspro SL2 unopened 8" powered sub
AZSky
Scottsdale, AZ
Heritage, Mach E, EV6
Asking $240 for never opened sub. Amazon has it for $380
Shipping info (?12x16x6 10lb)
Product highlights:
  • powered subwoofer with heavy-duty ABS plastic enclosure
  • 8" shallow-profile woofer
  • Class D amplifier (125 watts RMS)
  • 10-gauge amp wiring kit required (sold separately)
  • controls:
    • low-pass crossover variable from 50-120 Hz at 12 dB per octave
    • variable bass boost (0 to +9 dB at 70 Hz)
    • phase switch (selectable 0 or 180 degrees)
  • speaker and line-level inputs
  • frequency response: 35-120 Hz
  • dimensions: 13-9/16"W x 2-7/8"H x 10-1/16"D
  • MFR # SUBBPSL2AM
  • Item # 109BASPRO2
What's in the box:
JBL BassPro SL 2 owner's manual
  • Powered 8" subwoofer (15A ATC fuse installed)
  • 8" Speaker-level input harness
  • Remote level control
  • 16.5' Remote cable (RJ-25 connectors on both ends)
  • Four 2-1/2" Hex-socket screws
  • Hex-socket bit
  • Two 1" Philips-head screws
  • Quickstart guide
Are JBLs good for bass?
  • Punchy Bass: JBL products are known for their strong bass response, providing depth and impact, especially in genres like electronic, hip-hop, and pop.
  • Clear Midrange: Vocals and instruments in the midrange frequencies are articulated well, allowing for clarity in voice and instrument separation.
Ford Bronco JBL Basspro SL2 unopened 8" powered sub IMG_3273
Ford Bronco JBL Basspro SL2 unopened 8" powered sub IMG_3274
